Danielle and I will be ready, with duck on offer of course!
Use a small flat screwdriver to pop the lid off (looks like a flat £1, but it's quite deep), slacken the 13mm lock nut, then a T27 to turn it clockwise.superloopy1 wrote:I'm intrigued, i've got a 'flying saucer', tell me moreXac wrote: Screwing the T27 adjuster under the cap in the middle of the "flying saucer" clockwise several times has made a vast improvement to her oomph
No point, not on my old one anyway, as i had already tweaked it as far as it would go without failing the MOT on the smoke test. I went a step further and adjusted underneath the boost compensator so that the fuelling would come in sooner and hence less lag and more response.superloopy1 wrote:I'm a big coward when it comes to 'tweaking' but maybe this one will get a tryXac wrote:Use a small flat screwdriver to pop the lid off (looks like a flat £1, but it's quite deep), slacken the 13mm lock nut, then a T27 to turn it clockwise.superloopy1 wrote:
Make a note of the number of turns. 2-3 is a good start.
Tighten the lock nut and go for a test drive.
Welcome to the world of big grins.
You'll be smokier though, and use a bit more fuel.
