picasso has 4 garages baffled
- CitroJim
- x 6182
- Contact:
reblack68 wrote:I've heard EGR described as like farting up your nose. What is it supposed to be for?
The purpose of EGR Richard, is to lower peak combustion temperature and thus reduce the levels of NOx (Oxides of Nitrogen) emissions. NOx is a major cause of acid rain (Nitric Acid) and in the lower atmosphere, can react and create ozone which is good at high altitudes but is an irritating polloutant at low altitudes.
Although a diesel is clean in regard to CO emissions, due to the high peak combustion temperatures, the diesel NOx output is worse than a petrol engine.
EGR lowers peak combustion by admitting a portion of exhaust gas into the incoming fresh air charge.
As NOx is not tested at MOT time, there is no problem in stopping up the EGR system. Easisest is to disconnect and plug the vacuum hose to the EGR valve.
The cat on later diesels is there to further reduce NOx emissions by turning them into CO2.
- DickieG
- Monaco's youngest playboy
- x 38
I've had the EGR valve disconnected on my TD Xantia for years (and my present HDi Xantia for one year) without problems, but when I pulled the vacuum hose off of the EGR valve on my 2.0 HDi Berlingo the ECU picked it up and put the engine into limp home mode. Reconnecting the hose sorted limp home mode out, so you can try it and see what happens. When pulling off the hose make sure you plug the open end (use a small screw) otherwise it may affect other items such as the turbo boost.
13 Ram 1500 Hemi
14 BMW 535D Tourer
19 BMW i3s
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
14 BMW 535D Tourer
19 BMW i3s
06 C3 Desire 1.4
- My Cars: 2005 C5restyle 1.6HDI 16v 110hp VTR Estate
2008 C5 X7 1.6HDI VTR+ Saloon - x 231
Since seeing first hand the ghastly effects of the EGR I think they are detrimental to the engine at best. I would advise anyone and everyone to at least disable it from opening if possible.
deian, if you're asking for some pointers I'd be glad to help though I'm not sure how similar the ZX is to the xantia?
- mooseshaver
Your car stops dying?bencowell wrote:Benefits?
Gone cars.
C3 1.4 HDi 92 SX 52.
Saxo 1.1 East Coast.
Gone cars.
fix
does anybodythink main dealers are a bit expensive had a quote for he work to be done part is cheap labour at a main dealer is over £100 per hour and hey reckon mnimum 5 hours to fix it no other garage in my area will even touch the car so i have to get it done does anyone else think this is down right expensive
- mooseshaver
Main dealers are very expensive. Suppose they have to pay some kind of Tribute to Citroen.
If you can find a Citroen specialist in your area (they love Citroens, but don't like Citroen) then they would be cheaper, and probably better at the job too.
Problem is they are not always well advertised. The one I found in Cumbria wasn't on any web page for Citroen
Gone cars.
Gone cars.
