The Xantia 2.0 Hdi has recently started a slight hesitation.Only happens occasionally on light acceleration, but slightly disconcerting as i know this sort of problem is not going to go away.
Any thoughts on the likely reason?
Fuel filter p'raps?
Just passed it's mot yesterday with flying colours. The tester commented on how clean it was underneath for a 100 thousand miler. One of the best he'd ever seen in fact!
Lovely car, and absolutely no regrets so far after 3 months of ownership.
Slight hesitancy on Hdi
Colin
My cars:
1988 AX GT and still running sweet. Genuine 41 k only!!
2005 Skoda Fabia vRS 83k...and truly awesome.
Vauxhall Combo crew cab SE
Citroen Saxo 1.4 Furio.
Their cars:
Hyundai Getz.
Hyundai i20
Eriba Puck caravan now too!!
My cars:
Their cars:
Hyundai Getz.
Hyundai i20
- x 5
The hesitation that you are suffering seems to effect a lot of modern electronically controlled diesel engines.
My 1.9 DCi engined Renault Laguna suffers from exactly the same problem (along with countless others)....there are posts all over the Internet reporting this hesitation on all makes of cars.
I got rid of the problem by disconnecting the ERG valve...I pulled the electrical plug off it & the hesitation was instantly gone. Strangely no engine management light came on with the valve disconnected, although other Laguna owners have reported that theirs did.
I have read reports that the hesitation is due to the MAF (Mass AirFlow Sensor) being dirty or just getting old...some reports say that by replacing it the problem was cured...some don't.
I'm not sure exactly what causes this hesitation but I do know that the electronically controlled Diesel engine is nowhere near as reliable as the mechanical system that it is replacing.
2006 C4 1.6 HDi 16V (92) non FAP
2001 Xsara II 1.4 LX
2001 Renault Laguna II 1.9dCi Sport Tourer
Mine started hesitating and eventually got worse and worse, and the MAF sensor was to blame. The thing most noticable for me was when on very light throttle going down hill, the ECU couldn't make up its mind whether I was engine braking or accellerating, and it'd start to kangaroo very gently.uncle buck wrote: I have read reports that the hesitation is due to the MAF (Mass AirFlow Sensor) being dirty or just getting old...some reports say that by replacing it the problem was cured...some don't.
Martin
Old Faithful: Silver V-reg Xantia HDi Exclusive, died due to tin worm @ 259k miles
New Faithful: Silver W-reg Xantia HDi Exclusive, 169k miles and counting...
Previous: Various BX's, XM V6 24,
Venturi Atlantique 300, Alpine A610
