Ok will get all that done first. Thanks fellas
Do the GSF water pumps not come with gaskets then?
How long should the aux belt tensioner and pulley last for? As I may do it all while I'm there.
Likewise, engine mounts? I sometimes do get some jerkyness on easing off the throttle and again when depressing it. Came to my mind that it could be engine mounts. Don't think it's clutch.
HDi Timing Belt change
- CitroJim
- x 6182
- Contact:
GSF Water pumps do normally come with gaskets
The only mount that normally gives problems is the lower donut one and you can gain a good impression of it's health by looking at it. If it looks OK and you are unable to "rock" the engine backwards and forwards by grasping it, then it is most likely good. You can also get a good idea of how good the mounts are by revving the engine and observibg how much it moves. Oil leaks normally kill the lower donut and bad ones will have their rubber insides spilling out the sides.
The lower mount replacement job is a bit long-winded, needing the RH driveshaft to be removed so it's not a quick side-job you'd do whilst swapping a cambelt in any case. It's a big enough task to be carried out on its own merits.
Generally, with aux belt tensioners, if they look and feel Ok when you take the belt off, you can leave them be. Again, they are almost a big enough job to be tackled in isolation.
Concentrate on the cambelt for now Toby
- My Cars: M reg Xm S2 2.1td Auto Exclusive. 269k and rising
L reg XM S1 V6 12v Manual SEi
L 94 XM 2.1 TD auto total resto
2008 Peugeot 207 Sw 1.6 16v hdi. 217k and rising
2010 Peugeot 207 SW 1.6 8v HDi 161k and rising - x 71
Citrojim,citrojim wrote:GSF Water pumps do normally come with gaskets
Id just like to add, that on HDi 110 cars, the TOP small mount, the Tourque link one thats got 3 bolts through it onto the top of the suspension turret, this one breaks quite commonly....
The HDi 90 doesn't seem to break it... Luckily its only 26 quid or so from the Stealer...
Rgds
PAul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- CitroJim
- x 6182
- Contact:
Thanks Paul, very valuablecitroenxm wrote: Id just like to add, that on HDi 110 cars, the TOP small mount, the Tourque link one thats got 3 bolts through it onto the top of the suspension turret, this one breaks quite commonly....
I guess it's the same one that fails with some regularity in the Activa and 2.1TD
- My Cars: not applicable
The differences I've noted seem to be with ancillary systems. For example the EGR system on the C5 is inside a water jacket that feeds the heater, I guess this speeds up the heater warming as the EGR is normally used at low revs/part throttle when the engine will be slow to warm up. The C5 also has a 'Dozer' valve on the induction system which I'm told is to help with EGR function and help minimize the shut off shudder.
Doing the cambelt sounds similar to the 2.5 TD in that vernier pulleys are used, the idea with these seems to be that once the belt is tensioned the 'vernier' should be in the middle of the pulley slot.
Will be doing my C5 (DW10ATED) soon.
Steve.
Steve.
not applicable
My Xsara has this too, and I have found since disconnecting the EGR the coolant is slightly slower to warm up in cold weather.steelcityuk wrote: For example the EGR system on the C5 is inside a water jacket that feeds the heater, I guess this speeds up the heater warming as the EGR is normally used at low revs/part throttle when the engine will be slow to warm up.
