you do need the valves out whilst presure testing, otherwise you cant see wright down inside the ports were any cracking is most likely,
and buying a S/H head is no good as you would still have to have it presure teted and skimed to be on the safe side
regards malcolm
Cylinder head pressure testing/skimming in Bournemouth area
- CitroJim
- x 6156
- Contact:
I totally agree Malcolm, even that head that is apparantly brand new on eBay I'd want checked and given a light skim as for sure it will have picked up some dings and scratches underneath. A ding ar scratch on a part of the surface where the gasket fire rings sit will lead to problems.citronut wrote: and buying a S/H head is no good as you would still have to have it presure teted and skimed to be on the safe side
Mike, bottom line. Chances are very good that your head is OK and just needs a skim. Go for it. The lest stressful way. If a head man is any good, he'll pressure test it first and if it's dodgy he'll tell you and will only charge a nominal figure for the time spent testing it. My local head man did that for me with a suspect head and charged nothing...
