A friend of mine has a 309td with a leaking fuel primer which I think is integral with the filter housing. Is it possible to repair them? If not where can I get a replacement?
Thanks.
Peugeot 309td fuel primer.
The Ford one should work but it probably flows in the wrong direction so you might have to be creative with the mounting.
A used one will get you going but should be regarded as temporary. I expect most motor factors could get you one, or possibly Euro/GSF could send one.
Richard
Care of a 1994 205 D.
