Vince's XM...213k and slowing....
- x 187
- x 1617
- Donor 2020
- x 19
- Donor 2016
- x 12
- x 3
A quick update......with renewed vigour
The remaining "jobs to do" list is getting smaller....lets hope it continues to head in that direction
Things left to do:
- Dashbulbs - change duff ones
- Rear ABS sensor Drivers side
- Side rubbing strips - remove and fit new clips (i bought some off ebay and have now lost them)
- New mirror cover caps (The search is on)
- Heater - stop it blowing warm all the time (this is the most annoying fault of all)
- Rear suspension "niggle" -
The greatest thing about the above list is that i reckon i can complete the lot myself, apart from the last suspension related item. Jim has a similar issue on his so i am waiting to see what comes from his investigation before i think about mine
Tonight i realised that i need a garage and a 4 post ramp
Santa...please....ive been good
Things left to do:
- Donor 2019
- x 238
- x 17
I'm intrigued Mike, you never gave an answer to the riddle!MikeT wrote:I can see at least two parts missing![]()
One I suspect was intentionally removed but the other,
I suspect, would cause an emissions failure in the US.
But that sure is one shiney engine bay 8)
Filter housing leak off pipe from the hand bleed tap?
LHM Total sticker?
Sealing strip on the offside of the wiper scuttle?
Is there a plaque on some Xantia headlight panels?
You've got a nice looking car there Vince!
Andrew
- x 7
- x 3
Well...a small update.....
Some of you may have read that my Xantia is having an off day or three...
Well this is what has happened so far...
Since buying the car i have always taken care to not drive it hard...and especially to take it easy before it gets up to temperature. I have loved it and cared for it well, hopefully which can be seen in the condition the car is kept in 7 days a week week after week regardless of the mileage i am covering.
Irrespective of this, with 125K on the clock the head gasket has given up the ghost
Apart from the cost involved, this doesnt bother me that much as on any vehicle this can and does happen.....What is important though is that a good job is done on the repair.
For that fact it now resides in a Citroen speciliast garage who is carrying out the following work. Some as it is required, some because i want it doing whilst its in.
- Replace head gasket
- Refit rocker gasket
- Cam seal
- Crank seal
- Timing belt
- Water pump
- Glow plugs
- Crank breather hose
It should be ready for Thursday next week.....
Anyone fancy picking up the bill
See you back on the highways soon
- Cam seal
- Crank seal
- Timing belt
- Water pump
- Glow plugs
- x 3
- x 7
- x 3
- x 7
- x 3
The trafford branch sounds great. I used to run that place and drive past it every day on my way to and from work
If you can get them there then they can ring me when they land, i can either pick them up myself or have them shipped to Liverpool on one of my vans
There are a lot of new staff at Doncaster now and they wont know me. The main person who did was the branch manager Steve. Last i heard though he was thinking of leaving? ...perhaps he did?
