Then it was NOT untill 1997/8 R that the SX spec then got the standard spoiler as with S2 cars..
Ive got a spoiler on my V6.. and it DOES finish it off, im un certain if S1 and S2 rear bumpers are the same..
Paul
So has mine on my V6 Vince. Three little ripples along the lower edgevince wrote:My rear screen seal has lifted and split![]()
S1 and S2 bumpers are different, back and front.citroenxm wrote: im un certain if S1 and S2 rear bumpers are the same..![]()
Paul
Wish I could find where from, all the aftermarket ones I've found are 2 point not 3.citroenxm wrote:That WILL have been after market, Citroen Standard spoilers did not have high level brake lights
Paul
Citroën did produce a Xantia rear spoiler similar to what Xac describes but without the middle post, i.e. low and quite deep, available with or without an inset brake light as on the rear of this onecitroenxm wrote:That WILL have been after market, Citroen Standard spoilers did not have high level brake lights
Paul
Well if thats the case then Jim im stuffed....there is no way that you should not be able to remove the rear screen and seal. If not then if you broke your back window, even from new, then it would mean a replacement tailgateCitroJim wrote:Vince, in response to your text mesage earlier... The tailgate glass rubber is not removable easily from the tailgate. Mike and I tried with no success, even with a sharp knife.
As to wether or no it is available as a spare part, I'm not sure. I do have the body manuals at home and can look but I have a feeling the tailgate glass and its trim are all bonded in as one.
I'm going to watch mine s the weather grows milder and see what happens...
