Hi Everyone..
I think I have the correct gearbox code..
I've aquired a DERV gearbox for fitting to my XM 24v series one BUT, unfortunally, which may well be obvious when thought about, the bell housings are different.
So does anyone know or have an exploded diagram of one of these boxes.. or does anyone know what procedure is needed to swap them.. Ive got the bell house split away from the cogs but it wont let go (on the old box of course) any sugestions...
Ive posted it on here, as the Pug 605 would be the same and it may catch their eye too..
Many thanks in advance
Rgds
Paul
MLt5 Gearbox info wanted.
- My Cars: M reg Xm S2 2.1td Auto Exclusive. 269k and rising
L reg XM S1 V6 12v Manual SEi
L 94 XM 2.1 TD auto total resto
2008 Peugeot 207 Sw 1.6 16v hdi. 217k and rising
2010 Peugeot 207 SW 1.6 8v HDi 161k and rising - x 71
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
Which DERV box have you found ? 1.9, 2.1 or 2.5 ?
There will be stickers with both type & series numbers on the box.
I cant see how you would fit a BE3 (basic type) box to the V6 ?
The BE3 box will not last long when whipped around by a V6.
23/01/07 0269 01 3300 40 MANUAL GEARBOX 2,975L AND INJECTION AND 24SOUPAPES
95.644.406 NFP EXC MEC GEARBOX CP 16 X 65
TAG GM18 2GM07 2GM08 (2GMA8)
- 2,975L
2201.EY NFP EXCH TRANS AXLE CP 16 X 65
TAG GMK8 GM02 GM08 GM13 (GMK8)
2201.EZ NFP CP 16 X 65 TAG GMA2 GM12 (GMA2)
- ESTATE
12/08/06 0269 01 3300 55 MANUAL GEARBOX DIESEL AND XUD11A AND BE3/5NK AND CT22X18 AND SALOON
2200.NW (LE-0009) NEW MEC GEARBOX CP16X63
TAG CJ05 CJ72 CM13 (CJ72) (CM1C)
- 175X70X15 TYRES
CP16X63
- 185X65X15 TYRES
2201.AW NFP EXCH TRANS AXLE CP16X63
TAG CJ05 CJ72 CMA3 CM13 (CJG2) (CJK5) (CMAC)
- 175X70X15 TYRES
CP16X63
- 185X65X15 TYRES
27/04/07 0269 01 3300 60 MANUAL GEARBOX
DIESEL AND XUD11A AND BE3/5NKG AND CT22X18 AND ESTATE
2205.SL NEW MEC GEARBOX CP 19X77
TAG CH35 CH36 CH9J CH99 CJ01 CJ73 CM12 CM16 CM50 CM51 TA00 (CH9Y) (CJ73)
- 195X65X15 TYRES
2201.HV EXCH TRANS AXLE CP16X65
TAG CJG3 CJ01 CJ73 CJ88 CMAB CMA2 CM12 CM16 CM50 CM51 (CJG3) (CJK1) (CMAF) (CMA6) (CMEA)
- 195X65X15 TYRES
21/12/06 0269 01 3300 65 MANUAL GEARBOX DIESEL FUEL AND 2,088L AND TURBO
NOTE: TAKE ALSO 1 GEAR 2649.40 AND 2257 40
2222.H5 NEW MEC GEARBOX CP(15X59)-CT(21X26)P
TAG GM03 GM09 GM31 GM38 (GM31) (GM38) SEE NOTE + 2257.40
2201.V8 EXC MEC GEARBOX CP 15X59 - CT 20X25
TAG GMK3 GM03 GM04 (GMK3)
- UNTIL RPO No. 05368
2223.FV CP(15X59)-CT 21X26P
TAG (GMC1) (GMC8) GMC1 GMC8 GMK3 GMK9 GM03 GM09 GM31 GM38
- SINCE RPO No. 05369 SEE NOTE
- 2,975L
- ESTATE
- 175X70X15 TYRES
CP16X63
- 185X65X15 TYRES
- 175X70X15 TYRES
CP16X63
- 185X65X15 TYRES
- 195X65X15 TYRES
- 195X65X15 TYRES
Anders (DK) - '90 BX16Image
Hi
Its a DERV box out of a 2.1 1997 model year...
Do you need actual numbers? I asked about ratios before, and found that the original 24v box and the 2.1 DERV box were close enough to put one in..
Rgds
Paul
Rgds
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
Andres,
No i dont think.. the BOX is IDENTICAL on the outside, same construction etc etc. Its DEFENATLY NOT a Be3 box...
And being for a DERV it will be stronger...
I wouldn't dream of fitting a Be3 box in there, besides the gearlinkages are very different for BE3 and MLt boxes...
Thanks anyway... Anyone else?
Rgds
Paul
Rgds
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
