Zero compression on a Saxo
My Cars: Bluebell the AX, Polly the C3 Picasso, Pix the Nissan Pixo, Propel the duathlon bike, TCR Pro the road bike and Fuji the TT bike...
x 6204
Contact:
Post by CitroJim »
After a lot of hard work by the owner's dad and a bit from me, I'm pleased to say the car is now back on the road and running like it should.
£80 saw a replacement engine from the scrappy and it turned out to be a good 'un. We replaced the water pump, cambelt and clutch before we craned the new engine in.
We found two faults: One was a broken spigot on a pipe from the inlet manifold to the breather which let a lot of unmetered air in and caused a weak mixture and secondly, a missing rubber ring on the rad cap which would have upset the cooling system a little. The old engine had zero anti-freeze in it and the water was rather rusty; it looks like it had been consuming copious quantities beforehand and running hot. The cooling fan was running rather frequently before it went pop.
A good result all round. The only difficult bit was bleeding the cooling system. They're a right little bleeder to do :roll: and a header tank is essential for the job.
When I have some time, I'll strip the old engine and determine just how much damage occurred.
Those little Saxos really are a joy to work on :D
Xaccers
My Cars:
x 184
Post by Xaccers »
Glad you got it finished Jim! :D
DIY sphere tool
My Cars:
x 92
Post by citronut »
good to hear its been resusatated, they arnt usualy a job to bleed, i never use the header tank method on any of the cit/pug engines, maybe your bleeding prob was due to the crap in the cooling system
regards malcolm
Post Reply
