Or your ankles!moizeau wrote: 01 Dec 2022, 11:41I won't cause an engine bay fire on a bike but was it does do is causes the petrol to flow into the airbox, from there onto the swing arm, frame discolouring it or worse, flow forward into the cylinder(s) and fill the sump up. The Zeph was doing both. When I drained the oil when I first picked it up I got 7.5 litres out...... it should only hold 5.CitroJim wrote: 01 Dec 2022, 10:32 Float valve erosion is very worrying as a flooding carb is a good way to set an engine bay on fire...
We really are heading for some 'fun' times...
I think if I hadn't have bought it it would have died at some point because the PO wasn't mechanically minded.
Those of us running old carb bikes that aren't daily runners are already having lots of fun. I use an additive in all my carb engines, some in the club use a special ready mix at £5 a litre and brim the tank for over wintering, some drain the fuel system completely but this also has it's drawbacks if the bike is stored in a not absolutely dry environment. Rust in the fuel tank, corrosion in the carbs etc. Replacing a rusty tank could set you back £300 for a 70's Z, if you can find one, them another £200 to have it painted up to match the rest of the bike.
One chap lives near a small airfield and runs his bikes on 100LL Avgas. There are certain areas of the country (UK) where ethanol free fuel is still available, it's marked up as 5% ethanol (SP98) but these figures regarding the % are 'no more than' as opposed to an exact quantity.
- x 698
Re: Citrojim's AX, Saxo, Pixo, Running and Cycling Tales
- x 7246
I was shocked yesterday to see how rapidly E5 (Shell's finest) discoloured a length of clear plastic pipe I briefly used as a filter bypass... It used to take years back along!
I'd appreciate some details of that additive please Pete..moizeau wrote: 01 Dec 2022, 11:41 Those of us running old carb bikes that aren't daily runners are already having lots of fun. I use an additive in all my carb engines
I've heard the E5 from some of the major players is currently zero methanol but cannot recall which ones. I think it may have been Esso. It would be good to know definitively..moizeau wrote: 01 Dec 2022, 11:41 it's marked up as 5% ethanol (SP98) but these figures regarding the % are 'no more than' as opposed to an exact quantity.
And if it ignited it would give a whole new meaning to 'hot footing it...'
- x 6777
It is indeed Esso Supreme+ which is labelled 5% but the last I knew it was still 0%CitroJim wrote: 01 Dec 2022, 18:59 I've heard the E5 from some of the major players is currently zero methanol but cannot recall which ones. I think it may have been Esso. It would be good to know definitively..
- x 7246
Thanks Mickmickthemaverick wrote: 01 Dec 2022, 19:02It is indeed Esso Supreme+ which is labelled 5% but the last I knew it was still 0%CitroJim wrote: 01 Dec 2022, 18:59 I've heard the E5 from some of the major players is currently zero methanol but cannot recall which ones. I think it may have been Esso. It would be good to know definitively..
- x 6777
There used to be one round the back of the MK central shopping centre on Childs Way. I don't know if it is still Esso/there at all!!
- x 698
Mercury was the ankle winged Messenger. Does anyone know the Petroleum Company that used Mercury in its Logo.
- Donor 2023
- x 3178
National?
- x 6777
National Benzole?
- x 698
- x 7246
Not a part of the city I frequent Mick... I'm sure Zel will know...mickthemaverick wrote: 01 Dec 2022, 19:07 There used to be one round the back of the MK central shopping centre on Childs Way. I don't know if it is still Esso/there at all!!![]()
Not so long ago my local'ish Esso changed to a Total and I'm aware a few other filling stations have changed their identities fairly recently...
Be good to know the formulations of Shell V-Power and Total Excellum but most especially Tesco Supreme+ as that's where I get most of my petrol...
It works for me as I pop in at 6AM on the way to doing my food shop. The forecourt is nicely quiet then and I like using 'Pay at Pump'...
You beat me to National Benzol Mick
- x 369
Jim, the Esso Synergie is only available in certain areas https://www.esso.co.uk/en-gb/fuels/petrol
The additive I use is this https://www.amazon.fr/gp/product/B012RT ... UTF8&psc=1
Pete
- Donor 2023
- x 3178
Be careful using the 'Pay at Pump' option, Jim. It appears that some of the major Supermarkets are taking a 'deposit' of £100, holding onto it for a few days, and then (assuming no issues) returning it to your account. I wonder how much interest that is 'earning' them? If they have enough £100 'deposits' the interest could amount to quite a bit.
- x 5256
Try drowning some in Vodka or Gin and see how it fares. May not be the ethanol.CitroJim wrote: 01 Dec 2022, 18:59
- x 369
While we're on the subject of ethanol petrol, the bugger ate the insides out of my fibreglass TY250 tank. It now leaks at the seam and rattles.....oh and yes fuel pipe. cheap stuff goes rock hard in no time.
Pete
- x 7246
That's a shocking waste of good alcohol Steve!myglaren wrote: 01 Dec 2022, 19:37Try drowning some in Vodka or Gin and see how it fares. May not be the ethanol.CitroJim wrote: 01 Dec 2022, 18:59
It's certainly evil stuff... I wonder how many people realise it's horribly toxic.moizeau wrote: 01 Dec 2022, 19:43 While we're on the subject of ethanol petrol, the bugger ate the insides out of my fibreglass TY250 tank.
