I will say no more at this point until it is here with me Andrew... No, not seen on the forum before as far as I know...andmcit wrote:What's the story behind the new arrival
then - has it been seen before on the forum? Looks like a personalised
plate being so short?
Citrojim's AX, Saxo, Pixo, Running and Cycling Tales
- x 1787
- x 6
- x 17
- x 1787
Don't worry Andrew, I really was joking there... It was not the talk of a fuzzy 'flu-filled brain..andmcit wrote: Nooooooooooo!!! If you're going to the trouble go on, make it a hydraulic manual.
The only thing is though, the Activa ML5 gearing is a bit short for a V6 really. Mind you, scorching acceleration should be the order of the day but top speed would not be quite what it could be but who needs speed?
- x 52
- x 1787
Pattern is the same Paul. In theory you could fit a BE3 to a V6 as just like F0rd, many PSA gearboxes use the same bellhousing pattern and are pretty much interchangeable. I'm not sure this extends to the MA 'box fitted to the TU engines though...citroenxm wrote:How would you fit a box from a 4 cylinder fit to a V6 block??
The folks who put the CT engine into 205s mate it to a BE3 'box. Playing with fire really as the BE3 is good for about 150BHP tops. Much more and they tend to explode in the diff department...
One thing I need to establish is if the CT flywheel will fit the V6 crank tail.
- Sara Watson's Stalker
- x 5
- x 52
- x 5
- x 28
- x 1787
Adam, perhaps not go that far but...
It's well beyond my code-writing capabilities and electronic construction abilities (unless it could be made using valves) but the 4HP20 training manual explains pretty well the electrovalve sequences and timings. You could even go as far as manually selectable lock-up...
A paddle-shifting V6 Activa - what a thought
Not with the standard Xantia/406V6 ECU Toby but with a custom ECU it should be possible to write the software to implement a 4 speed paddle shift on a 4HP20.Toby_HDi wrote:I wonder if you could also somehow make the manual mode option work in a Xantia.
I'm thinking along the lines of Alfa 166 Sportronic. It's a ZF 4HP20 box but with a manual mode too though a different casing I believe. Find a way of sticking it in a V6 Activa - best of both worlds!
- Monaco's youngest playboy
- x 17
