I found myself in need of some spanner therapy today
So after a particularly good 30 mile virtual bike ride around Watopia I set about doing some preparatory work to replace Daffodil's RH driveshaft, wheel bearing and brake disc/pads...
I also used it as an experiment to see just how well I could work on the suspension within the confines of my bijou workshop... Very well as it happens and that bodes well for when the weather really turns...
I have to push Daffodil's rear end outside and work with the garage doors open but that's much better than being totally outside
- Daffodil amongst the spanners...
For now, the hub nut has defeated me. However hard I tried I just could not keep the car on the ground... I was either lifting her or spinning the engine over... I'm going to need assistance to get the nut loose!
That did not stop me doing a trial strip of the brake components...
- Thin as a fag paper!
The disc and pads are well worn...
I found the caliper very tight on its sliders so removed the caliper complete to clean and lubricate the sliders...
- The caliper minus pads...
I tried to retract the piston but even with plenty of force from a G Cramp it won't move... I thought opening the bleed nipple might make it easier to retract the piston but the nipple is very tight and I'm wary of applying too much force...
I'm soaking it in Plus Gas and will do so over a period of days in the hope the nipple will undo successfully... Maybe a bit of carefully applied heat will help too...
The track rod end balljoint was no problem at all
- An easy win!
As was the lower swivel through-bolt
- Lower swivel
The boot on the outer CV joint - the failed one - is not well secured and much nasty grease had escaped and made a mess...
It just goes to prove that cable ties, even a pair of them, do not make good CV boot clips
- What a mess and what a bodge...
I hate spilt CV grease and hate cleaning it up even more
Lots of brake cleaner helped...
Once this side is done, a repeat performance on the LH side, less driveshaft, will take place
Before it all goes together again, all will receive a good clean up and a lick of black paint
Happily, no 'nasties' found - on this side at least.....
