Citrojim's Pixo, Saxo and Cycling Tales
x 1054
Re: Citrojim's Activa, 207 and Bike Tales
Post by CitroJim » 12 Oct 2017, 11:17
Hell Razor5543 wrote:
12 Oct 2017, 11:03
I wonder if coating the cable in Waxoyl might help cut down on the wear?
I believe they're designed to run dry as they run in Teflon coated outers James...
I fear Waxoyl may be far too viscous for such an application in any case - especially in the cold!
Some PTFE lube might be a good idea though - I must do some further research ;)
elma
x 212
Post by elma » 12 Oct 2017, 22:21
I had 2 cable policies Jim.
Number one was to use the cheapest acceptable cables and outers. I'd buy the inners in bulk and replace them often. The outers I'd spray through with gt85 until it ran clean. I didn't have a compressor back then, I'd use a bit of gt85 and blow them through nowadays. Outers I'd only replace if they perished or had housed frayed inners.
Number two was to buy super expensive Gore Ride On cables that have a larger inner diameter on the outer. This allows them to use a third plastic tube essentially that you slide the inner cable into and makes them mud proof. It's by far the best cable system ever but costs about as much as a used entry level bike. Hence it was only ever on my best bike.. I'm not sure they would be a good idea on your Ultegras though. They'd be amazing but if the angle of the cable inside the shifter is so acute it damages the cable quickly it would be horribly expensive.
Regarding grease so far as I've seen some people put a little bit of grease into the outers with a grease gun, others just do a little dab on the cable near the shifter so it's in the first section of inner. Personally I think it's a bad idea because it tends to attract dirt that degrades the performance of the cable. As a mountain biker though I encountered different elements to you though so maybe it isn't a bad idea on road bikes.
x 1054
Post by CitroJim » 13 Oct 2017, 09:55
James, thanks for that :) Good, interesting information!
One reason I was reluctant to apply any lube of any sort was that the old inner was very sticky (with oil or grease perhaps) and in consequence had picked up a load of contamination on its exposed parts and this, I felt, may well have contributed to its failure.
On my bike there's very little conventional outer at all, just a few inches from the shifter to the frame egress point and then another few inches from the frame exit point to the deraillier. I did blow these two short lengths of outer clean with the air line.
The gearchange is now beautifully silky-smooth and precise; a joy to use in fact and better than it's ever been :)
Donor 2016
x 678
Post by Stickyfinger » 13 Oct 2017, 10:21
Locksmiths stock graphite power in "puffer" bottles......great stuff.
x 1054
Post by CitroJim » 13 Oct 2017, 11:48
Stickyfinger wrote:
13 Oct 2017, 10:21
Yes, now that's an excellent thought Alasdair ;)
If it's good enough for locks then...
Donor 2016
x 678
Post by Stickyfinger » 13 Oct 2017, 13:03
x 1054
Post by CitroJim » 13 Oct 2017, 13:45
Just what the doctor ordered... In fact some is now on order ;)
Zelandeth
Donor 2016
x 300
Post by Zelandeth » 13 Oct 2017, 21:33
Here's one possibility Jim - though it is somewhat dependant on my managing to shift the Skoda rapidly (which I'm hoping will happen soon as the longer it sits around the more trouble it will cause me).
How about I take custody of the Activa, paying an amount we could probably agree on, get a test on it and give it a bit of regular exercise to allow us to produce a to do list in the unlikely event that there actually is one. Then come the spring, which I've found tends to be the best time to sell classics I look to sell it on and we split the proceeds - or if it turns out that I wind up sufficiently attached to it, I buy it in full myself for a price we could agree beforehand.
Either way it gets it out from under your nose quickly, and could well wind up with you getting a better price for the car than trying to sell it rapidly. Also means that you don't have to do any of the interfacing with the buyer at the end of the day.
I'm typing this while rather jetlagged so I might have made it sound more complicated than it needs to be...if it can wait a couple of weeks I'm more than happy to drop by to have a face to face chat on the topic.
...equally, if someone offers you a good price, go for it!
Being honest I'd love to own one anyway, I'm just a bit apprehensive about the complexities of maintaining an Activa long term, and also I only have so much parking space!
x 1054
Post by CitroJim » 14 Oct 2017, 04:58
Zel, I reckon there's a good plan brewing there ;)
Maintenance of the Activa would be no issue as you'd always have me just around the corner...
We must discuss at great length when you return - a perfect excuse to go somewhere good for a coffee :)
Donor 2016
x 678
Post by Stickyfinger » 14 Oct 2017, 10:01
Some cleaning may be required......but do not worry Jim my OCD will get to that before you pick it up :)
There is not one bit of shine on it :)....time to get the jet wash and machine polisher out !
daviemck2006
Donor 2016
x 299
Post by daviemck2006 » 14 Oct 2017, 10:57
That will be a good set of befores then. We shall soon see the afters and see a big difference.
x 1054
Post by CitroJim » 14 Oct 2017, 11:42
Excellent Alasdair :) She's looking very good in the pictures :) I take it she's now at yours then...
I may be able to come and collect this coming weekend if a cunning plan works out ;)
Don't worry too much about cleaning her...
Donor 2016
x 678
Post by Stickyfinger » 14 Oct 2017, 13:27
CitroJim wrote:
14 Oct 2017, 11:42
hahahaha.....you are talking to me Jim.....that is not going to happen !
Donor 2016
x 678
Post by Stickyfinger » 14 Oct 2017, 13:46
Cleaned (Jet washed) the engine bay.....
And did a very quick pass with some compound using the machine polisher on the front wing to see how the paint cleaned up....it has quite a LOT :)
x 1054
Post by CitroJim » 14 Oct 2017, 16:27
Wow! That's looking wonderful Alasdair :) Can't wait to see her in the metal ;)
Is that the original battery on her? Surely not!!
