- x 1743
Re: Citrojim's Xantia Activa, 1.9TD and Bike Tales
Living "On the Edge of Danger and Flicking the Finger to the Law" is over now then Jim
- x 7251
Yes, I'm now known and the official keeper of GabrielStickyfinger wrote:Living "On the Edge of Danger and Flicking the Finger to the Law" is over now then Jim
- x 7251
Just been out for a truly magical drive in my Activa
I love that car so much...
Now I have new insurance on her with more miles allowed I can enjoy her properly again
- x 102
The automatic gearbox sump plug on the Bx has chisel marks on it and seized solid. Frightening. I changed the fluid by undoing the large fixing nut on the bottom of the filler tube.
Sent from my Wileyfox Swift using Tapatalk
Dave
- x 7251
There's just no excise for that kind of butchery is there Dave?
Mind you, from the witness marks on Gabriel's sump plug it looks like someone had a fair tussle with it back along... I have a lot to thank Zel for there
Zel was telling he how tight the old glowplugs were yesterday...
- x 102
Luckily the Synergie has started fine in the cold weather so hopefully the glowplugs will last a while.
Dave
- x 7251
Seems the colder it is the better they start Dave... As long as glowplugs and valve clearances are good... I reckon the pump is more efficient at pumping cold - and therefore slightly thicker - diesel.. Have you ever noticed they need just a little more spinning when hot to start?
I've wondered why that is the case for years and once asked a long-experienced diesel engineer who spent his days rebuilding and testing pumps, mainly Bosch... Hot vs. cold fuel viscosity was his conclusion. Every Bosch pumped 1.9TD I've owned has been the same...
- x 102
Cold weather denser air? Maybe?
Dave
- x 7251
Yes, that is most likely to contribute too Dave...
- x 1299
Oddly though the 1.7TD used to start without plugs after even a good while stood - thought there was something wrong with my first Xantia 1.9TD when it wouldn't start hot without the plugs after coming from BX TDs!!
- x 7251
Ahh, the 1.7 would have had a Lucas pump I expect Richard... A far superior pump in all respects. Plus the 1.7 I believe had a higher compression ratio which in turn made starting less reliant on good glowplugs.
All the 1.7s I've had were the same. A brilliant engine...
- x 1299
Nope, both mine were Bosch pumped....!
Edit...I think.... I'm not so sure about the second one I had, might have been a Lucas - didn't have it for that long!
- x 102
Err so a few pages back we were talking plips.
Jim are these 90's cars programmable without a lexia? There are a few complete plips available on the bay and I was wondering if they can be programmed with the old button push and ignition key twirling method?
Dave
- Donor 2023
- x 3179
It depends on the plip. If the car is a S2 Xantia it will need to be programmed with a Lexia, so as to introduce it to the car (all keys will need to be done at the same time, as any that are not done will be 'forgotten'). Once this has been done the central locking bit can be done (IIRC turn the key to 'M' position and then press/hold a button until the locks react), as now the car will accept an input from the key.
- x 7251
Dave, as James says... If it's like the S2 Xantia (i.e. RF at 432MHz rather than Infra Red and has an RFID chip in the key for the immobilser) then it's a Lexia job and additionally you'll need the confidential code for the CPH... If you have no keypad then the immobiliser is more than likely an RFID one...
Else as for the S1 Xantia using the procedure that James describes...
RF plips can be identified by having no forward facing LED lens and a generally much longer range...
