That's XMs for youHell Razor5543 wrote:Now why is that not a surprise?
Exactly JamesHell Razor5543 wrote:What you need is a good barn to keep the fleet dry, with space enough for a well equipped maintenance workshop.
That sounds like a productive day Jim. Those 20K service intervals don't sit well with me, no doubt by then there is more fuel than oil in the sump. A recipe for disaster with a 1.4/1.6HDi.CitroJim wrote:I'm not that good Malcolm, blindfold possibly but I do need my hands....
I was thinking of doing a photo-strip of the ML5 but as they're so reliable it's likely a waste of time. If anyone wants one though, shout...
Today, as it was such a gorgeous day, we gave Robyn's little 207 a badly needed service. The oil had been in there for nearly 20,000 miles and it was in an awful state. The plugs were so worn the gaps could have accommodated a double-decker bus but apart from that it was not too bad. These 20,000 mile services seem far too distant to me.
Robyn had a few instances of the engine cutting out on approach to roundabouts and so on. We had the Lexia (Pug Planet) onto it and re-initialised the engine ECU to recalibrate the auto-adaptives which mainly sets up the correct idle and overrun fuel cut-off. I'm hoping that fixed it as Robyn finds it a little scary at times and tomorrow she's off to Oxford for a University interview at Brooks. She's looking to do a nursing degree.
I've decided, after yet another drive of it yesterday, to keep the XM..
KP wrote:I'd switch Robyn's car to a 10k service interval Jim if you want it to last as the first thing to warn you it's going to die is going to be a dying turbo, then injectors, then before you know it compression goes on one pot...
10k is the way forward for them and if you know someone with an xud Bosch they can use the waste oil to run it
The WFA standardCitroJim wrote:It'll be a lot less than that Will. As Paul says, it's a 1.4 petrol and does nearly the same miles to the gallon as my V6...
I'll now bring it into a 6,000 mile service schedule...
Same motor in that 306 I look after *is* meant on a 6,000 mile schedule. The counter goes back to 6,000 when I reset it.CitroJim wrote:It'll be a lot less than that Will. As Paul says, it's a 1.4 petrol and does nearly the same miles to the gallon as my V6...
