Not sure i would say they are great.
My brother has just px'd one against a Kia Soul as his clutch was just letting go at 40k and just over 3 years old....
Citrojim's AX, Saxo, Pixo, Running and Cycling Tales
- x 1787
- x 52
I've heard a lot about hydractive having an appitite for threshold... however. My hdi exclusive 110 has so been the opposite... I've so far got 20k out of 4 tyres... hard/soft mode does work too....
Paul
Bloody predictive text... TYRES not threshold ......
Paul
Paul
Paul
- x 1787
- x 1787
- x 81
Great news on the MOT Jim!
My fiance drives very gently and is currently on 15k miles on her Michelins. They're only 50% worn too!
Am quite happy if she can make a set of fronts last for 25 - 30k miles on her Xantia HDi Exclusive.
When I drive it I feel guilty as the torque off the 110 is quite adictive!!
David.
David.
- x 6
- x 28
- x 1787
- x 1787
A very interesting day yesterday
Xantia V6 was due to visit for a height corrector swap. At the appointed time I heard a nice low burbly V6 sort of sound approach my house and looked out at a big, bright red car in my drive. That's an odd colour for a Xantia. It was an odd Xantia too, one disguised as a V12 E-Type Jag
The E-Type had gathered an advisory on one of its rear wheel bearings and we took a look.
It was an education of many parts, from knocking off the wire wheels to seeing exactly how the jag IRS rear suspension was engineered. In the event, the wheel bearing was OK but there was still play. On the IRS the drive shaft forms the suspension top link and there appeared to be a lot of play in the outboard UJ. To check, it was necessary to free the driveshaft from the hub - the two are splined together in the conventional way.
"That's easy!" the owner said "One little tap after the hub nut is off and the spline will come apart..."
One little tap did nothing, bigger and bigger taps did nothing, mighty taps did the same as did a puller
The splines were well stuck together.
Finally we removed the hub and driveshaft complete so that we could apply the hydraulic press to the job. This we duly did and expected the splines to separate meekly and without fuss. One ton, 2, 3, 4, 5, pump, 8 tons, 9.... Not a peep. Finally at 10 tons the press red-lined with no movement from the shaft at all... The driveshaft was really well stuck in the hub.
After a few re-applications of 10 tons with no result, we then soaked the assembly in good old Plus-Gas, let it soak in and then tried the press again. 10 tons came up on the gauge and still no movement. Pressure released and reapplied and then BANG!!! it finally let go
And all because of a tiny bit of corrosion on the splines. A bit of a polish up with Scotchbrite saw them then sliding together and apart a treat.
The outboard UJ (A Hardy-Spicer joint) was found a bit worn and attempts were made to source a new one locally...
Shockingly, nobody around here stocks parts for '72 E-Types
Disgraceful.
So, all we could do was reassemble and order one in. Reassembly of a Jag IRS is fun. The lower hub pivot is critically shimmed to a very, very tight clearance and getting those shims back in is an art
Finally, we set up a dial gauge to measure the bearing play on both sides to check it was in limits.
Working on an E-Type was a very enjoyable diversion from the usual Citroen stuff
The E-Type is a gorgeous car and the V12 sounds heavenly
Today I'm off to chase down a very tiny LHM leak on Old V6...
- x 121
Well done Jim. Another Hardy Spicer(gkn) may have crossed over from Land Rover or the like. Trouble is that parts guys don't have time to rake through stock as they only deal in numbers. Rimmers would have that UJ?
I have seen 15 ton on a small crankshaft BSA big end..............nothing.
Did the guy have 2 ES94 engines bolted in under the bonnet then?
- x 47
- x 534
I phoned about 10 motor factors in the region, and 9 of them said they don't carry any UJs any more, and one was out of stock of that size.lexi wrote:Another Hardy Spicer(gkn) may have crossed over from Land Rover or the like. Trouble is that parts guys don't have time to rake through stock as they only deal in numbers.
The Jag half-shaft UJ is fairly beefy, they are used as driveshaft UJs on trucks, but could not find one yesterday.
The rear hub on the other side came apart with hand pressure (last time I had it apart).lexi wrote: I have seen 15 ton on a small crankshaft BSA big end..............nothing.![]()
- x 1787
No, 10 tons is a bit girly, I agree. It's just that I only have a girl's press and it maxes out at 10 tons...lexi wrote: I have seen 15 ton on a small crankshaft BSA big end..............nothing.![]()
Yesterday and today's adventures makes me think I really need a 20 ton one...
Toby_HDi came for a visit today to have new wheel bearings and swivel joints fitted to his 406 Coupe front hubs. They're all but identical to Xantia ones..
One set of bearings pressed out OK but on the other side a bit of rust had got to grips with them and we saw the press redlining at 10 tons again. Once again Plus Gas helped and finally the bearings gave up the struggle..
I normally hate swivel joints but today they were so easy. Toby brought with him a five foot long 400 ft lb 3/4 drive torque wrench. That and my old blacksmith's vice made very light work of them indeed!!! My 3 foot 1/2" breaker bar would not touch them. I have something to add to my shopping list now - a giant 3/4 drive breaker bar and some matching usefully sized sockets....
During the work, Trooper30 and Xac popped in to make it into an informal FCF mini-meet
After the hub fun, Toby and I had a look at his Activa. We found his suspension stuck firmly in hard mode and after seeing the ECU had recorded a permanent fault on the rear electrovalve, we found the electrovalve to be short-circuit. This is an unusual failure but I guess the internal diode which usually fails open-circuit decided to fail short-circuit just for a change.
We proved it was not the wiring at fault by disconnecting the electrovalve and what a hellish job this is on an Activa
All in all, a very good day
