by bumper removal - the intercooler is everywhere. Most likely removal of the
battery box support etc.
Yes but as a rule I don't use it on the TCT. I prefer my time-honoured and trusted method of being able to turn the belt through 90 degrees on it's longest run between finger and thumb with moderate pressure.robert_e_smart wrote:Do you have a SEEM gauge Jim?
No, I don't think so as the old belt was pretty much spot-on tension-wise and the whine was a recent addition to the soundtrack. You know me, the whine was not especially bad, just enough for me to be aware of it...DickieG wrote:do you think the belt was too tight as that can cause a whine?
That car is definitely female, requires lots of attention and money spent on itCitroJim wrote:As always, the Activa has thrown another small toy. After a bit of a spirited drive I thought the exhaust sounded a bit different. A quick inspection showed the back-box to centre section joint is failing and both parts are in need of replacement. Next job: a new exhaust![]()
Of that there is no doubt RichardDickieG wrote: That car is definitely female, requires lots of attention and money spent on it
