A friend has a saxo where the ABS light is on. He borrowed a known-working sensor off a donor saxo and replaced the F/O/S but no change so did the same on the F/N/S and still no joy.
Any ideas apart from replacing all four? Where is the ABS ECU located and does anyone know the pinouts or test procedure for the wiring?
Saxo ABS
im not sure if the Saxo ABS sensors are fitted through a cast iron lug, but if they are it would be only luck to be able to salvege one without damageing it,
i cant remember what the values should be when useing an ohm meter, but i alway used to check them this way, and normaly the one which was at fault would show open circuit,
recently my son tells me i need to test these with an indutance meter to get a true reading,
regards malcolm
ps.
also i think the guy had only tried to two front sensors, and again i have not worked on any Saxo ABS sensors as yet
regards malcolm
ps.
I think the sensors are a simple coil wound round a former - and so a simple continuity test is all you need - as either it conducts or it doesn't.
For a BX the resistance is about 950 ohms and I'd imagine saxo ones would be a similar value.
Generally its the leads to the sensors that fail - and it has been known for people to repair them by carefully soldering in a length of suitable co-ax cable.
jeremy
