Story is I had the drivers side door apart looking at why the electric window was not working. Turned out someone had removed the reg alltogether and the glass was propped up with wood!!! I had an unfortunate short when a wire came out of one of the connector plugs and interfaced with another. Cue mild smoke! Switched the car off changed the fuse which had gone as a result and all seemed well. Then removed the plastic trim from drivers side A Pillar so I could feed thru the microphone cable for my Parrot Bluetooth kit. So far so good but later in the day when driving no power from fag lighters! Boo. Checked fuse and that seems ok.
Should add that I've had the radio out of the Xantia because its being rubbish and I want to fit a new non standard one. Could I have knocked the wiring out for the fag lighter do we think?
