Xantia 2.1 TD, Should I scrap it???
- CitroJim
- x 6182
- Contact:
2.1TD water pumps are different to 1.9TD ones and because there is not so much demand for them, I guess they're dearer. 2.1s are not nearly as common as 1.9s and also, 1.9s use a water pump that is also used on a myriad of other XU engines.
Front spheres are dead easy. Set the suspension on low and depressurise by undoing the 12mm pressure release bolt on the pressure regulator by half a turn. Do't remove it or else you'll loose a ball bearing.. You can't miss the pressure release bolt; it's the only 12mm bolt there, in fact one of the only ones on the whole car.
Use your sphere removal tool to unscrew the spheres clockwise. Have some rag under to catc any spilt LHM. There may be a lot if the spheres are really flat.
Clean up any spilt LHM. Take the new sphere seal and dip it in clean LHM. Insert the seal into the groove on the strut top and NOT on the sphere itself. Screw in the new sphere hand-tight only. It does not need to be mega-tight to seal.
Do up the pressure release bolt, start up and allow pressure to come up. Then set the suspension on high and top up the LHM reservior. Take the suspension from high to low to high to low to high (a procedure we call "Citarobics" - this bleeds any air from the system). Recheck your LHM level and finally set the suspension normal. Job Done.
Whilst you are there, check your strut tops. They can corrode. Do a search for how they can fail and how to check them.
- My Cars: Currently:
In the past: 3, CX td Safaris and about 7, XM td estates. Lovely cars. - x 1204
The outer spheres are quite easy, as they are under the bonnet they shouldn't have coroded, the centre is more difficult to get at but shouldn't be to difficult with a removal tool.
Set the suspension to its lowest setting, no need to depressurise the system further, fit the tool and unscrew the spheres. The under bonnet ones should come undone quite easily but the centre one will probably be corrode thus tight. If you open a door, then close it, waiting until you hear the 'clunk' of the electrovalve closing, do this three or our times and it should depressurise the centre sphere which will make it easier to unscrew. Once you have 'cracked' them, they should undo easily by hand.
When refitting, smear some grease or waxoil on the the threads, just in case you need to replace them again, and only screw them up hand tight.
sphere maynem
Hi All,
well I got up this morning and replace the two under bonnet spheres myself.
I couldnt believe how easy it was to change the two under bonnet spheres although I thought I had de-pressurised the system but when i took the first sphere off it shot lhm about 20 feet from the sphere and made a hell of a mess but soon got over it, the second one was easy as anything but I could not get the accumalator off so will get the mechanic to do that one when he does the belt next week.
Thanks for all the advice..tim
1997 Xantia 2.1 TD SX Estate
New lease of life
Hi all,
well i decided to have all the work done so this week i had all the front spheres replaced. New cam belt, tensioner and idler pully.
New water pump and coolant and anti freeze etc.
Its booked in for two new tyres and a full service next week so should have a decent car and hopefuly a xantia owner for many years to come.
Thanks....tim
Thanks....tim
- falling-out-with-my-car
- My Cars: Citroen C5 Aircross 8 speed Automatic, Flair Model with far to many toys and nice comfy armchair like leather seats. ha ha Ive just had a conversation with the car. setting everything up verbally
- x 24
timbo101,
I know its a long time since your orriginal post but I wanted an SX 1.9TD estate so bad I bought one that had been sitting under a tree for five years and paid £1300 for it with no mot, I then paid a mobile citroen mechanic another 2 grand to replace rear brake pads, cambelt, serpentine belt, glow plugs, clutch, a complete set of suspension spheres, LHm flush, a new radiator, rocker cover gasket,front brake pads, front and rear discs and remove the catalytic converter and put a straight pipe in its place.
I have owned my car 4 years it passes its MOT with ease nearly every time except to say for silly things a slightly bald tyre or a slightly white indicator lamp suspension spheres need doing soon again its an ongoing concern but in my opinion worth every penny I spent.
I also waxoiled the whole rear end of the car underneath which cleans up any suspicious rusty looking parts that an MOT station might get confused with a failure (they don't understand citroens very well).
rergards Nigel.
rergards Nigel.
