That can be done Stu Take a fully mechanical Bosch pump, injection pipes and injectors from an early Citroen or Peugeot 1.9TD and it'll go on and work. The problem is the ECU as it drives the tacho (if it has one) and controls the glowplug controller. I have a horrible suspicion the Lucas ECU also drives the speedo. The Lucas EPIC on my 2.1TD appears to but you may be able to leave the old ECU in place just looking after the speedo and glowplugs.stuartadair wrote:He came up with this crazy idea of taking a standard injector pump from a 405 which he believes is the same block, without any electronic guff on it and trying that on.
At the very least, you'll need to provide an ignition switched 12V supply for the stop solenoid and then it'll run. You may have to experiment with timing and fuelling a bit to get it sweet.
Note that from about '95 on, most PSA 1.9TDs will be found fitted with a semi-electronic Bosch pump with a keypad immobiliser, ECU and armoured, tamper-proof pump. These are more difficult but could be transplanted. You'd need pump, injectors (No. 3 is special as it has a needle-lift sensor), ECU, engine loom, double relay, and (initially at least) the keypad. Thn you'd need to do a good bit or wiring mods to make it all work. It's doable but the early mechanical pump is a better bet.
Wheeler, I believe it's the DW8.
