MikeT wrote:XantiaMan583 wrote:There is a rubber pipe/cover with a small hole in the end, removing this oiled dripped out?
Do you mean the vent that sits on the side? It maintains atmospheric pressure to the underside of the turbo plunger diaphragm? It looks like a small rubber boot with a short outlet pipe that goes nowhere.
As Mike says, this vent is below the diaphragm and should be bone dry. It will bear investigation as the oil may be getting in there through a small split in the diaphragm. It's very easy to check but take care as you lift the diaphragm not to disturb the relative alignment of the pin and cone under the diaphragm. Naturally the top side of the diaphragm will be very oily as it's in direct communication with the inlet tract and breather fumes but the underside should be totally dry.
MikeT wrote:Perhaps you should consider asking if Jim would sell you his spare pump and get it fitted asap. That way you can examine/rebuild your pump at leisure.
Unfortunately, I only have a couple of fully mechanical pumps in stock. I do have a semi-electronic but it needs a complete reseal and has been my experimental pump. It works though, it was removed to resolve a masive leak.
On that car, whilst I sourced a replacement semi-electronic (more by luck than judgement!) I temporarily fitted a mechanical pump and left the ECU to pump connector dangling, just picking up an ignition-switched 12V to operate the stop solenoid. The only niggle was a constantly illuminated "K" light. Otherwise it works out very well
For the complete job £400 is reasonable. It's a a good 3 hours work to remove the pump, 2 or more to reseal and have it running up on the test-bench and then the same time to refit or longer if as like I did first time I did one, lost the woodruff key down behind the cambelt tensioner
