citrojim wrote:I had a bit of an investigation into this problem on my Activa yesterday although not to the extent of replacing the flexi hoses. That is next.
Good - I await with interest
I bled my brakes and found zero air in the fronts but a massive gulp of air in my offside rear. A good 250mL of frothy LHM came out. Strangely, the other side rear was completely air-free.
Yep, thats exactly what was happening on Dad's car - always on the right hand side (offside ?) and never on the left. There was so much air that you could brake hard and the rear suspension had time to hit the TOP bump stops before the brakes would activate and pull it down again.
That has cured my initial delay problem. I also replaced the pedal spring to make the test a harder one and what I find now is although I have no delay, the first few cold applications are not really very good but once the brakes are up to temperature, they're OK. The hotter they get, the better they work. I'm suspecting it has racing pads in it.
Are you sure its temperature related though ? Didn't you say that a few hard applications of the brakes while stationary had the same effect ?
They're about 3/4 worn now so come the next bout of fine weather, new discs, pads and flexis will go on.
Great - but could you do them as two seperate jobs ? Otherwise we will never know which one was the problem and/or how much of what symptoms were related to each item.
The air worries me although it may have been a result of upsetting things replacing a front height corrector, else I have a leaking sphere. They're all very recent except the anti-sink. If the problem (and air) returns, this sphere has to be No.1 suspect...
That'll be anti-sink sphere for sure, based on your other comments.
A blast around last night and a 100 mile round trip today leaves me fairly content with my brakes although they're still not quite as good as my 2.1...
See what they're like after a day or two of not driving them...
Regards,
Simon
