What engine oil to use?
Cpt_Spalding
My Cars:
Post by Cpt_Spalding »
The voucher does say from £20. I phoned another branch this morning, said I had the voucher & what would be the cost, telling them my make & model.
Reply was £26 inc VAT + £10 if they have to remove & replace any plastic sump guard. No additional oil disposal charge.
'98 Xantia 1.9TD Tempt 2 Estate.
Had an M reg long ago as co. car & been curious about owning again ever since.
What have I done????
den169
My Cars:
Post by den169 »
It has gone up i got my c5 done in january for £20 it shows £26 now but if you put a 2000cc petrol its £20 same oil semi 10-40 oil when i go again i'll book it as a petrol plus i have a £5 voucher they sent me.
KP
My Cars:
x 27
Post by KP »
Well just phoned myself and its gone upto £30 but the voucher gets me £5 which i think isn't too bad and may still book it in if it saves me getting under the car for 30mins to change it and the mess then it cant be too bad :)
N_CURTIS
My Cars:
Post by N_CURTIS »
I bought some Silkolene Ashford 15/40 from here http://www.opieoils.co.uk/ thru' ebay at £25 for 10 litres inc. delivery.
I'm running the ZX (1.6i petrol) on Tesco 10/40 (£7.47 for 4 litres) at the moment, but I thought I'd splash out on something a bit better.
I went for 15/40 to see if it will slow the ZX's thirst for oil.......
It will also do for our other car which is an '89 Nissan Micra which has made me learn all about points and condensers at the side of the road!
KP
My Cars:
x 27
Post by KP »
Opie oils are very good and if you join as a member of a club they can often give discounts :D
MikeT
My Cars: 2005 C5restyle 1.6HDI 16v 110hp VTR Estate
2008 C5 X7 1.6HDI VTR+ Saloon
x 232
Post by MikeT »
My car doesn't like the tesco's 15W diesel. It's not so smooth running until it gets fully warmed up :(
XantiaMan
My Cars:
x 17
Post by XantiaMan »
MikeT wrote:My car doesn't like the tesco's 15W diesel. It's not so smooth running until it gets fully warmed up :(
I reckon thats the SVO not the engine oil :wink:
I used Tesco oil in my Montego for many 1000's of miles, had the head off twice, at 160k it still had honing marks. The actual oil is made by Carlube aka tetrosyl, nothing wrong with it all, the only problem with it is this time of year, mornings are getting colder, its quite thick at low temps, fine when up to temperature though but this is why i wanted to see if people have tried with different grades.
My engine still uses very little oil so going to a 10w 40 should not bring a noticeable increase in consumption and will help a little with mpg and smoother running when its really cold, as it takes longer to turn an engine over with a thicker oil than a thin one, because of the extra drag on the rotating parts etc.
2003 Ford Mondeo ST220
2002 Ford Fiesta Zetec S
2001 Ford Puma 1.7 VCT
2008 Ford Transit Mk7
http://www.facebook.com/kidmans" onclick="window.open(this.href);return false;
THELABMAN
My Cars:
Post by THELABMAN »
I have had two oil changes at two differnet national outlets now and both cost £26.95, £20 for the oil change, £5.95 for engine flush additive and £1 for dispoal of old oil.
Citroen C5 2.0 HDI SX Hatchback - 2002 (52)
Xantia Sensation 1.9TD (T) Mallard Green (Gone to the breakers)
Post Reply
