Heater blower
KennyW
x 163
Heater blower
Unread post by KennyW »
Hi gang,
Going over an old subject, the blower has stopped working and this is a resistance module only 9 months old !!!!!!
I've ordered some more transistors hopefully here soon any tips for fitting to module.
I've got heat sink compound and the original module to play with, going to complain to dealer re 9 mth old module and try and get new one to replace same since it is less than a year from purchase.
Any suggestions will be gratefully received.
Kenny
C3 1.4 petrol (SWMBO)
x 8072
Hi Kenny,
Blower Transistor replacement guide here:
http://www.frenchcarforum.co.uk/forum/v ... hp?t=22348
MikeT
x 232
Re: Heater blower
Unread post by MikeT »
KennyW wrote:...replace same since it is less than a year from purchase. Any suggestions will be gratefully received.
Kenny
I am convinced my blower failure was the result of water ingress. Is there a possibility you haven't cured the cause of the original failure? Just a suggestion.
KennyW
x 163
Thanks for the replies, Photo's are great Jim but after all that.
I did the job and still no Blower :cry:
I've checked the fuses and they have not blown.
I did a quick check and got only one reading from one of the wires.
Can't remember what it was though and which wire.
Question time for forum.
What should i check and in what order?
Any answers will be gratefully received.
Kenny
MikeT
x 232
I can't recall what wire gives what readings, sorry.
But if you haven't been through this already, the engine has to be running before the blower will work. It tends to catch a lot of people out, me included. :roll:
x 1238
Unread post by Peter.N. »
What transistors did you use? Could it be they were not rated high enough? They also need good contact with the heat sink, not to much compound. I used ordinary PNP transistors and I have never had them fail, I found out afterwards that they should have been Darlingtons!
Clogzz
x 40
Unread post by Clogzz »
Hi Kenny,
Welcome back to fans, blowers and wires.
Some ideas here:
http://www.frenchcarforum.co.uk/forum/v ... hp?t=21758
2002 C5 2.0i AL4 239,000 km 76372389
KennyW
x 163
Hi team,
I got the same transistiors as Peter N.
I've tried both old and new resistance control module and the heater blower does not work at all.
I did the replacement in Feb 07 with a new unit, got it on special!!!
The heater blower was working but at the time i thought it wasn't as good as the original.I put it down to my imagination :lol:
I am trying check the supply voltage into the blower and what wires have a permant feed etc.
I hope this helps.
Kenny
KennyW
x 163
Hi Team,
I quickly checked the thick red and black wires which go into the blower
0 v being read through meter.
Unable to check further ie the F21 fuse rated 30amp to see if it is getting a supply.
Any ideas gratefully accepted.
Kenny W
KennyW
x 163
thanks for all the replies and ideas,
After all the fuss :lol: , I had time this afternoon to check the voltage running through the circuit and found my problem.
It was the relay which had gone, supply in through No3,when I put old relay in and checked supply to control module nothing.
I found a relay in my box of tricks of right type but only 25amp and blower works.
Will get new heavier relay tomorrow.
Any suggestions as to what size?
Simon's blower entry 40 amp relay.
All the best
Kenny
Clogzz
x 40
25 Amps should be just enough, but the problem is that there are many components that are not up to their claimed ratings.
There is also a rating for the interruption of the current when the relay releases and sparks; don’t know what that’s called. :?
My relay says 30 Amps, and has been good for 9 years this far.
I would have doubts about a relay in the same size casing saying 40 Amps.
The Citroën modification says 30 Amps for both the relay and the fuse.
RichardW also says at least 30 Amps:
http://www.geocities.com/tricky992002/fanmod.xls
KennyW
x 163
Thanks Clogzz,
I got one today rated 30 amp and i'll keep the other one as a spare.
At least I'll not have steamy windows :wink:
Kenny W
P.S. Clogzz still working on the aircon, I'll need it working for France next year :!:
