My Activa is due its MOT next week (well not until the end of October but I'll take it a month early) and I notice one of the bulbs is blown in the high-level brake light (the one in the boot lid).
Is it an MOT failure?
How do you open the light to replace the bulbs and what sort of bulbs are they?
A brief look has not revealed how to get into it
High-Level Brake Light Bulbs
- CitroJim
- x 6204
- Contact:
- DickieG
- Monaco's youngest playboy
- x 38
Don't do as the handbook suggests and try levering it out from the outside as you'll break it. The way to get to the bulbs is to open the boot then look for a rubber plug behind the light, remove it then use a long screwdriver or socket extension to apply pressure to the spring clip to release it outwards.
IIRC the bulbs are 5w capless.
13 Ram 1500 Hemi
14 BMW 535D Tourer
19 BMW i3s
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
14 BMW 535D Tourer
19 BMW i3s
06 C3 Desire 1.4
'13 3008 1.6 HDi GripControl - x 1003
According to MOTuk.co.uk, from the Tester's manual:
"High level stop lamps
These are lamps usually fitted in the rear window or boot spoiler of a vehicle and may consist of a number of light sources .
The lamp is one unit, so as long as at least one of the light sources illuminates when the brake pedal is pressed the lamp is deemed to be working"
No bother then
No bother then
- My Cars: 2005 C5restyle 1.6HDI 16v 110hp VTR Estate
2008 C5 X7 1.6HDI VTR+ Saloon - x 232
Re: High-Level Brake Light Bulbs
According to the BOL;citrojim wrote: A brief look has not revealed how to get into it
1.Open the tailgate
2.Push the clip & open flap covering rear of light unit
3.Disconnect wiring plug(s) then depress two retaining tabs & withdraw bulbholder
- CitroJim
- x 6204
- Contact:
It's in the BoL is it MikeMikeT wrote:According to the BOL;citrojim wrote: A brief look has not revealed how to get into it
1.Open the tailgate
I never even think of the BoL these days
I'm sure there's a very good reason why, Jimcitrojim wrote:I never even think of the BoL these days
- CitroJim
- x 6204
- Contact:
I looked behind that gromment Richard. If I had foot-long fingers I may have got to the light All I succeeded in doing was cutting my finger on the sharp edgeDickieG wrote:On my V6 facelift you can simply remove the rubber grommit above the trim.citrojim wrote:For the facelift, the BoL is just that, a liar
There is no flap and it's a case of removing the complete inner cover
