Following on from the previous problems that I had before. When I come to start the engine there is not even a click from the starter solenoid. I have checked all the fuses, but could it be a relay? There is no voltage getting to the solenoid.
Thanks in advance
Xantia 2.1
- CitroJim
- x 6206
- Contact:
Is the rest of the car alive electrically? If so then as Peter says, ignition switch or its associated circuitry.
You can test the starter and its solenoid quite easily by disconnecting the solenoid wire and running a wire (of adequate size) direct from the solenoid to the battery.
- My Cars: Currently:
In the past: 3, CX td Safaris and about 7, XM td estates. Lovely cars. - x 1207
I suppose that the earth connection hasn't come off your engine? Try what Citrojim suggested, run a lead from the battery+ terminal and just touch it on the solonoid connection (but make sure it isn't in gear) If its only the supply from the ignition switch that's missing, you could run a couple of leads inside and treat yourself to a 'push button' starter.
