Can anyone tell me the exact physical locations of the following Hydractive 2 sensors on a Xantia ?
* Brake pressure sensor (connected to the pressure line to the front brakes, somewhere....)
* Road speed sensor (on the gearbox somewhere presumably, but where ??)
Thanks.
Regards,
Simon
Xantia Hydractive 2 sensor locations ?
Simon
1977 G Special 1129cc LHD
1978 CX 2400
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
- CitroJim
- x 6156
- Contact:
Hi Simon,
The first I don't know but the second, the Speed Sensor (VSS), on a BE3 gearbox is mounted on top of the extension to the diff housing on the offside (long) driveshaft side where the speedo cable would have been connected in the old days.
Any problems with the VSS and the speedo won't work.
Hi Jim,citrojim wrote:Hi Simon,
Opps, should have been more specific - I've got the 4HP14 automatic gearbox. Also I mean the speed sensor for the Hydractive 2 computer, not for the dashboard speedo - or are they one in the same ??
Regards,
Simon
Simon
1978 CX 2400
1978 CX 2400
Found the brake pressure sensor!
Don't need to find the other one as the problem is now fixed! See:
http://www.frenchcarforum.co.uk/forum/v ... hp?t=22301
Regards,
Simon
Regards,
Simon
Simon
1978 CX 2400
1978 CX 2400
