Sorry mate, but most of that (about the A/C) is frankly bollox
TehAgent wrote:
I cant see how something of this design can use more fuel as the compressor is very easy to rotate by hand (trust me Ive done it) this would have minimal effect on the actual engine rotation its self and a electromagnetic brake wouldn't need that much from the battery to engage with enough force to hold the wheel in place while it rotates.
Whilst the clutch might be an electromagnetic brake, the compressor is not - it HAS to take energy from the engine to run it. After all your fridge doesn't get cold unless you plug it in does it?
TehAgent wrote:
Then we have the heater matrix, when the engine is running and the AC is off, my car idles at just below 1000rpm, when the AC was on, it still ran at just under 1000rpm. so it wasn't having any effect on engine rotation and thus not using anymore fuel than it was at idle, (as a example car, my friends mondeo 2.0si, creeps above the 1000rpm mark soon as the AC is on, and thus does have a effect on fuel consumption)
Diesel engine has a governor - as the A/C loads the engine up the governer injects more fuel to keep the engine revs the same. You will notice a slight shudder as the compressor kicks in, and then tend to find you need more revs to pull away - this is the effect of the work the engine is doing to turn the compressor.
TehAgent wrote:
IIRC, a car battery draws in 14amps from the alternator when it is running, to keep the battery charged, this would be plenty and the AC would not need to draw more from the battery than what the battery is getting (or your battery would go flat pretty fast)
The load on the alternator varies depending on the electrical load. On a dry day with no blowers, once the start charge has been replaced the alternator will be doing little. On the other hand on a wet, dark, day just after a cold start with the blower on full the alternator will be working hard. Diesel engine alternators are usually rated somewhere around 80 amps. When you are running the A/C the engine cooling fans run all the time too - this will increase the load on the alternator by a not insignificant amount. It used to be the case that A/C cars had bigger alternators and batteries than non A/C cars - this is possibly still true for petrol cars, but probably not for diesels (bigger alts and batts to compensate for high starting currents required).
TehAgent wrote:
Some of what i said might be wrong,
8)
What ever anyone says using A/C WILL use more fuel. It simply has to - you don't get something for nothing (well unless you increase the boost on a diesel engine, when this IS possible
). How much will depend on the sort of driving you do, the ambient temp, the state of the A/C system, the size of the engine, etc etc etc.
