EGR pipe disconnected
- My Cars: 2005 C5restyle 1.6HDI 16v 110hp VTR Estate
2008 C5 X7 1.6HDI VTR+ Saloon - x 232
Thanks to this forum I've identified a loose pipe that should go to the EGR valve - which explains why my car always idles a little high (appx1000rpm). From what I've read, it's ok to NOT have EGR but is it ok to have the pipe unplugged (will it cause any problems) or should I seal it off with a bung or something?
Hi MikeT,
Was your engine management light on, or hasn't your car got that system.
Thanks,
Greg
Thanks,
Greg
90 Kawa EN 500 A1- was running---now dead again
04 Kawa GPZ 500 E10 -alive and well.
54 Fiat Punto 1.2 Dynamic
Old Xantias- 16v 2litre 1997 VSX, 2 x 1993 TD Lx, S2 SX 1.9TD
Old Bx's--3 x 1.9 D, 1x 1.6 Auto, 1 x 1.9 GTi, 1 x 1.9 TZS
Hi Gregg1100, I have an engine silhoutte light with an asterisk I think, in the middle that comes on with the ignition and soon goes out. It has never lit up out of turn on me even when I had both ABS and airbag on constantly. Does that mean something to you? I'm not sure what should or shouldn't trigger the engine management light though suspect hydraulic and engine temperature sensors are likely candidates.
