My ZX is making impolite noises...
Post Reply
KEB1
My Cars:
Post by KEB1 »
OK so coincidentally (I hope) since I had that tyre fitted and both front wheels balanced, on slight left or right turns of the s wheel when maneuvering what is best described as a momentary impolite noise can be heard from the steering system (power).
I jacked it up and had a good look round both sides and can't see anything out of place.
On the road it feels like new and handles extremely well due to the new tyre.
I have a few theories, which I hope are wrong, but has anyone else actually experienced the same occurance ?
Kristian. :?
1993 ZX 1.4i Aura
1984 2CV6 Club
1972 Dyane 6
Past Citroens
1975 CX
1972 GS Club
My Cars: Currently:
In the past: 3, CX td Safaris and about 7, XM td estates. Lovely cars.
x 1206
Post by Peter.N. »
I know it sounds obvious but have you checked the fluid level and the belt tension?
jeremy
My Cars:
Post by jeremy »
Other things to check - seizure of the column universal joints - usually felt as high or stiff spots as the wheel is turned.
Many ZX have Bendix front brakes - which are notorious for harmless but alarming knocks when reversing - as the pads move in their sockets.
If it occurs when rotating the wheel and continues for a few moments - then fluid level would be the first place to check. I did have a PAS pump fail - bearings went and oil leaked onto the pulley which made it easy to trace.
jeremy
My Cars: Bluebell the AX, Polly the C3 Picasso, Pix the Nissan Pixo, Propel the duathlon bike, TCR Pro the road bike and Fuji the TT bike...
x 6204
Contact:
Post by CitroJim »
jeremy wrote:Many ZX have Bendix front brakes - which are notorious for harmless but alarming knocks when reversing - as the pads move in their sockets.
Don't they just, especially if it has been damp and the car has not moved for a few days. The first time it happened on my 205 I stripped the calipers looking for the problem :oops: :lol:
Another possibility for the noise is binding in the strut top bearings.
KEB1
My Cars:
Post by KEB1 »
Hi All,
Thanks for all the replies. I checked everything that could be relevent and all seemed OK.
However, the noise has gone as mysteriously as it appeared. I was getting a bit concerned that it might be expensive like the rack or ram but there is a strong possibilty that there may have been air in the system.
If it was air, I don't know how it got in as there are no obvious leaks or fluid loss.
At present, all seems ok so fingers crossed.
All the best,
Kristian. :D
1993 ZX 1.4i Aura
1984 2CV6 Club
1972 Dyane 6
Past Citroens
1975 CX
1972 GS Club
Post Reply
