BrianA wrote:I put some of that thin plumbers tape around the flared pipe and then screwed the nut back in,that couldn't have caused any problems could it?
Brian -
I have to say this is an absolutely wrong approach working on Citroen hydraulics.
The threaded union nut does not in itself make the pipe join leak proof.
The union nut is only used to press in the flared pipe end - AND (most importantly) compress the rubber seal which then clamp against the pipe surface & the pipe bore inner surface. This way the pipe union is made leak proof.
Please forget
ANYthing about waterpiping, plumbing, pressure airlines etc, as Citroen hydraulics deals with a working pressure of 170bar. This is about 20 times the normal pressure in anything else you know off. In fact only industrial hydraulic equipment really compares to it (albeit working with higher capacities).
You MUST leave the plumbing approach of thinking, when working on Citroen hydraulics. It can proove lethal to you or oher trafficants if you try repair the system piping using plumbing approaches.
Adding to Simon's advice you must be aware that :
1) the rear brakes will only work (have pressure to the master cylinder) if & when the rear suspension is loaded by the car's own weight (and/or goods in the trunk) - OR when full pressure on the rear suspension is forced by the full height setting on the manual lever.
2) when the wheels are dangling in the air, the HC will sense this like the car is in highest position possible (wheels farthest down from chassis - as if the car was set high standing on ground) thus closing off the pressure if height is set to normal.
3) the rear accumulator ('antisink sphere') has nothing to do with the rear brakes pressure as long as the engine (and thus pump) is running & supplying hydraulic pressure. Its only there to provise a reserve of rear brakes pressure during drive if the engine (and pump then) stalls. This accumulator sphere is rather amusing to remove as the pipe will twist if you try unwind the sphere, not removing the pipe first.
There is a very good technical guide written for Citroen newcomers here :
http://www.tramontana.co.hu/citroen/guide/guide.php
I recommand you download it, print it out and use it for self study. Its the best documentation that exists on Citroen hydraulics, passing on the technichal details, but still respecting that many readers may not be too technical inclined.
