Hi, can anyone help?
The digital clock on my wifes Xantia II keeps playing up.
It can work for days without a problem then without warning the display disappears. It may take a few minutes before it comes back. Sometimes it starts really faint and after a while returns to normal, other times it comes back on at normal brightness. It also resets its time and date but not always. I suspected a bad earth, but on looking at the circuit diagram it shares its earth with other items, but these aren't affected.
Also the temperature display seems to read approx 20ºC higher than actual temp. i.e. when its about 20ºC outside, it will read 40ºC or there abouts.
Anyone got any ideas?
Cheers,
Graham
'98 Xantia II Combined Digital Clock/temp display
Xantia II 1.9TD SX Estate.
1999 'T' 230,000 miles and rising!
My BX clock has a nice arrangement - it dips when the sidelights are put on. It would dip on its own - and an electrical surge like switching in the wipers would revive it.
Problem - well after fiddling with its plug etc I took it apart and examined the circuit board with a magnifying glass - and found on 3 joints near the plug the solder has cracked. Some careful re-soldering solved the problem.
jeremy
