xantia jerky
xantia jerky
hi guys me again no sooner sort out 1 problem than another appears.i now have a slight judder on gentle acceleration.its definately engine related but its not a misfire.if say free wheeling approaching a junction in second or third and then gently accelerating away the engine chuggs a bit untill the revs pick up,im not going to slow for that gear because i can also get the engine to do it if i gently accelerate untill it starts to chugg then i can keep it there with the accerator at that speed and it will chugg untill i increase the revs it does it in all gears but as i said when the revs pick up it drives normally it ticks over properly and performance has not dropped off,it has had a italian decoke last week after which the car performed great untill yesterday when this started.fuel filter was changed approx 3 thou ago,im presuming its fuel delivery related?its at the speed you would drive around the town centre so its really annoying.any ideas?oh and the fuel let off pipes were changed 2 weeks ago for new citroen items.
xantia jerky
sorry guys its a 1.9 td on a 95 m plate
- CitroJim
- x 6204
- Contact:
You've done all the usual suspects
I'd first look at the boost sense pipe between the hot side of the turbo and the injection pump. This pipe often perishes and lets in air, upsetting fuel metering.
Also, generally check for air leaks on the turbo trunking and the intercooler.
A remote possibility if you have the older non-ECU controlled Bosch pump is the cold advance has stuck. This is controlled by a little solenoid on the front of the pump. When cold, 12V is applied which goes off as soon as the coolant is warm (above 60 degrees). To test, on a cold engine, firstly check you have 12V there, disconnect with the engine running and listen for a change in engine note. When hot there should be no voltage present.
