for not a lot of money you could change near enough all the pipes.... though your problem sounds like a throttle not returning quick enough...never had a 2.1 does it have a little hydraulic ram thing (like a very small boot support) to close the throttle?davethewheel wrote:my 2.1td also has bubbles that i can see in the clear section of pipe they seem to be made worse if i squeeze the bulb, i've had a problem since i got the car, it's as though you still have you foot on the accelerator as when you dip the clutch the engine revs rise, i always thought that it must be a problem with the ecu or the pump maybe it's related to air in the fuel.
if it does they do wear out (and cost about £100 to replace)
you could also have a frayed/worn throttle cable not allowing the throttle to close
try manually opening the throttle under the bonnet...it should snap straight back...if it doesnt you have a throttle problem
