xantia estate
xantia estate
I need something bigger than the car I drive since I now own 2 dogs. So I was thinking maybe and estate or some 4x4.
I dunno if I want a french car tho, not that my xsara has been unreliable, I've been lucky with that in that its been perfect, but form the reputation of french cars I dunno if I wanna tempt fate.
Can anyone reccomend the xantia as an estate or should I go for a japanese 'safe' option. I'm really skint so I'll have under £1000 and cant afford in no-way to pay for big repairs in the future so I need something I can trust.
Jamie
Jamie
- My Cars: Citroens since 1990, BX Diesel, GTI, TZD with 1.9 TD running extra boost before it was fashionable!, ZX Volcane TD, S2 Xantia break 1.9TD, Xantia HDI 110, currently zipping about in a C2 Diesel. C2 died from the dreaded worm, C3 Picasso HDI Exclusive, the adventure continues.
- x 31
- Xaccers
- x 184
Xantia's are lovely, I have 2 estates, both diesel.
One of the best things about them is that you can do most servicing and repairs yourself so saving a fortune.
Personal preference is for a SX/Desire grade as its high spec (a/c, electric windows, radio with input jack for ipod etc) but doesn't have the extra spheres that you get with hydractive Xantias.
Expect to have to change all the spheres, that's 6x£20 (+£10 for a home made tool), and maybe hydroflush the LHM (£17 for the hydroflush and £20 for new LHM).
Course you may not need to, but for both of mine I've had to within a few months of buying them.
The diesel 1.9TD should get you over 40mpg, and if you get one with a bosch fuel pump, can run on a diesel/vegetable oil mix (don't forget to pay the extra duty!)
The diesel engines are nigh indestructable. I've filled an engine with water before, and had the cam belt snap doing 40mph on the M25, just had to replace the broken parts (cam, caps, belt tensioners and belt).
DIY sphere tool
DIY sphere tool
A Citroen, that's an estate AND 4x4!!
Here's a rare bird:
http://cgi.ebay.co.uk/RARE-Citroen-BX-4 ... dZViewItem
Where's Britton BTW - is it a district in Peterborough of something!?
Andrew
Here's a rare bird:
Andrew
Mothers is going well for 185K, 2.0 Auto Exec. Fully loaded with all the toys, Pulls like a train & not bad on the jungle juice as long as you don't drive it like you stole it.
Coupes more than well with our dog (newfoundland) - you'd get 2 in there with room for a poodle.
Check the door hinges as they can fail, noticed mothers has started to crack around the drivers top, causing the door to misalign.
I plan to fix this before it gets too bad, just need more numbers on that 12 hour dial
Would we have another? mmmm no - we'd have a C5 2.2 exec!
- CitroJim
- x 6156
- Contact:
I saw a very late BX TZD Turbo Estate last evening in our Tesco car park. Even had a brief chat with it's owner. I love the looks of them 8)mugatea wrote:Ok, tell me honestly and objectivley, is the old BX any good? If so what is it like compared to the xantia and is it a solid dependable car?
I'm getting drawn towards its retro-geek looks. It's kinda cool.
thanks
Jamie
They have simplicity going for them and an arugably better ride. In fact, if you get an early Mk1 Xantia, effectively, they're just a BX in a new set of clothes and without the dreaded octopus They even sink like a proper Citroen should
The Xantia gets ever more complex as it gets newer and not always for the good
It is said that the Xantia is a better made car and is certainly a lot heavier than the BX. The BX should be nippier and more fuel efficient.
BXs generally look scruffy now, even the "L" reg one I saw last night looked very weary and needed lots of TLC but it looked sound enough so there may be some truth in the build quality rumours.
How they withstand rust I'm not sure but I've heard the boot floor rusts a bit.
I'll leave others to continue but I do recall in 1992 tears being shed in the caravan press when production of the BX ended. It was said to be a tremendous towcar. An accolade the Xantia never quite carried forward as I recall.
Go for one!
from what i feel from others on the forum and my own general feelings, the bx is a good car, but the xantia is better... of course there is more to go wrong on the xantia due to the newer technology, but the bx was a good car in it's time, probably very under-rated, i'm not sure how strong the 4x4 system on the bx is... i.e transfer boxes etc... and it don't say what engine the bx has, if it's the diesel then you may as well buy it for under £500.
- CitroJim
- x 6156
- Contact:
That has got to be worth getting if only for its rarity! It looks good.. Spares will be a problem though for the 4X4 specific bits although I guess a lot will be shared with the Pug 405 Mi16X4. Transfer boxes are weak. I'd not risk too much towing with it.andmcit wrote:A Citroen, that's an estate AND 4x4!!
Here's a rare bird:
Andrew
A classic waiting in the wings I think, well on a par with a BX16 GTi
Anyone know if it has the Mi16 engine? He has not said, perhaps to keep the 205 boys at bay
If it is an Mi16 with only 51,000 miles the 205 boys will be wetting themselves Low mileage Mi16 engines are now practically extinct.
Britton may be in Somerset That was where the car was first registered.
(I think he means The United Kingdom 'cos I can't spell the alternative that begins with B either!!!!)
