1.While I'm still trying to get a hold of a 4th activa alloy to complete my set, and with my journey to Wales next week for a holiday (yay!) I thought it may be possible to swap my steel wheels from my LX estate, which also happens to have some much better rubber on them at the moment.
Only problem is the activa has 205/60/15 all round and the boots on the lx are 2x 195/65/15 and 2x 185/65/15. Would I encounter any problems swapping them over? (in know the speedo would read incorrectly)
2. Other day went for a nice drive (45 miles) coming back about 5 miles in to journey doing about 70ish and the speedo went haywire , up, down, hovering, sat at zero, very fast movement - did this for a few miles, worked again at speeds of around 30-40 then decided not to work. Very similar to this post from the sound of it: http://www.frenchcarforum.co.uk/forum/v ... edo+xantia
Anyway checked out the transducer on the gearbox still looked in place, reckon that's the fix?
Also, interestingly, if you check my other thread on this car, you will know that the K-light was coming on when I boot it hard up through motorway speeds. Well since the speedo broke it doesn't do that any more Hurrah! It now sails right past 100-110 (estimated
Once again thanks for reading..
