idle
idle
forgot to ask this my engine (1.9 td) ticks over a bit lumpy the idle speed is ok and it drives smoothly its just when idling it seems a bit rough any ideas thanks
idle
sorry car is a 95 on a m plate 1.9 td xantia 155.000 miles. i presume it's bosch there is no smell of diesel or visible leaks at the pump as you suggest.this rough idle happens at all engine temps regardless of how long the engines been running
The point I'm making is that on a car fitted with a Bosch pump hard/cracked leakoff pipes will allow air to get into the fuel system and may cause misfiring, even if there is no external diesel leak. Roto-Diesel pumps are rather different and are unaffected by the state of the leakoff pipes - and indeed a couple of times I've had major leaks (one split pipe and one failed end cap) on our ZX 1.9D with a Roto-Diesel pump and the only indication that something was wrong was the smell of diesel.
jeremy
- My Cars: Citroens since 1990, BX Diesel, GTI, TZD with 1.9 TD running extra boost before it was fashionable!, ZX Volcane TD, S2 Xantia break 1.9TD, Xantia HDI 110, currently zipping about in a C2 Diesel. C2 died from the dreaded worm, C3 Picasso HDI Exclusive, the adventure continues.
- x 31
I just found and repaired a split leakoff pipe on the BX (Bosch pump) symptoms were smoking and spluttering at startup, then increasingly difficult starting, eventually failing altogether, and a serious lack of power which I only found after fixing it
Stewart
Stewart
idle
ok seems the general feeling is leak off pipes.the pump is bosch my next question is where are the leak off pipes?are they the ones that go from injector to injector?thanks guys
- My Cars: not applicable
