Brake Fluid Renewal C5
I intend renewing the Brake Fluid on a C5. Has anybody any advice to offer. In what sequence, or in what order should the system be bled.
- CitroJim
- x 6208
- Contact:
I'll not argue with the French Authority but back in the old days of conventional braking systems, it was always rear brakes first followed by the fronts. The idea was start far away from the master cylinder and work your way to the slave cylinder closest to it so that would be RL, RR, FL and FR. In this way you get the air out of the longest pipe runs and any brake load compensators first.
I take it the C5 is fully conventional in the brake department?
Unfortunately you are wrong.wrinklet1 wrote:Correct me if I am wrong, bu, isnt a C5 like a Xantia in that the brake fluid is the suspension fluid and not a seperate liquid?
The C5 has seperate conventional vaccum servo brakes.
Regards,
Simon
Simon
1977 G Special 1129cc LHD
1978 CX 2400
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
- CitroJim
- x 6208
- Contact:
Hence my point of how I was always led to believe conventional brakes should be bled! Or have I been doing it all wrong these past 30 years Knowing me, there is a good chance I have as well...Mandrake wrote:Unfortunately you are wrong.wrinklet1 wrote:Correct me if I am wrong, bu, isnt a C5 like a Xantia in that the brake fluid is the suspension fluid and not a seperate liquid?
Regards,
Simon
yep the C5 employs the completely standard 'old style' DOT fluid vacuum assisted brakes system.
You must go to the deeper innards of your garage and dig out your old 'brakes bleed kit' from ancient times where you had some kind of a BLMC in your driveway.
Except you will need yet another new lid for the bleed kit
Anders (DK) - '90 BX16Image
- CitroJim
- x 6208
- Contact:
Vizibleed is what you need. It's a one-way valve that fits over the bleed nipple via a length of hose and sits in a pot of brake fluid. Makes it nearly as easy as doing a Hydraulic Citroen then and is a one-person job.AndersDK wrote:yep the C5 employs the completely standard 'old style' DOT fluid vacuum assisted brakes system.
The Eazibleed system I think you are referring to Anders, uses a pressure source, usually a tyre, via an adaptor cap on the master cylinder. The pressure head forces fluid out when the bleed nipple is opened.
I've never liked them much. I always eneded up with an engine bay covered in brake fluid resulting from an imperfect seal on the master cylinder causing a brake fluid shower
- My Cars: 2010 Citroen C5-X7 tourer
1998 Citroen Saxo 1.5D
2018 Citroen C4-B7
1998 Peugeot 306. 1.9D
2011 Citroen C1 - x 72
- Contact:
Seems there's no rhyme nor reason for order. Bleeding instructions for the Xsara go - RH rear,LH front, LH rear, RH front. For the Pug 306 order is - LH rear, RH front, RH rear, LH front. Could it be that the Xsara has ABS and the Pug hasn't?DickieG wrote: but Xantias should be bled in the same order; N/S/F, O/S/F, N/S/R, O/S/R.
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
Thanks everybody for your comments & help. That was why I asked the question JohnD - there seems to be neither rhyme, or reason to the order of bleeding brakes. Although the C5 is Dot4 fluid and different in this respect to the Xantia - the bleeding sequence is similar. Is it true that the sequence should always start nearest to the Master Cylinder. I take it that NSF is the side nearest to the Steering Wheel, as we understand it here in Ireland & the U.K.
