You need to work out how the XM rev counter works. I think they get pulses from the flywheel sensor.lolingram wrote:Only downside is the rev counter does not work so must pick it's signal up
from/through the pump
//Chris
Did you fit the cold start device to it as well?
I was tempted to convert mine but never got around to it.
I take it you changed the injectors and pipes as well. Did the accelerator cable fit onto the pump without any mods?
