Hi Laurie,
Just seen your thread.
Sounds like you found the problem just in time.
Yes, I have heard that before, welding the pulley to the crank.
On the BX, you can change the belt without removing the pulley, just remove the plastic bit at the bottom, held on with 2 bolts, that gives enough clearance to get the old belt off and the new one on.
May be the Xantia is similar...
Good luck Brian
XUD TD Bosch pump problem
Had to do that on a 306 when I could not budge the bolt. The bottom cover wraps round the pulley, so I had to break it to get it off. But there are two bolts holding it on, and I have come across other broken covers. It doesn't seem to matter.G4EIY wrote:On the BX, you can change the belt without removing the pulley, just remove the plastic bit at the bottom, held on with 2 bolts, that gives enough clearance to get the old belt off and the new one on.
Brian.
Oh well, in that case (the cambelt is nearly new) I'll just degrease everything, file up a nice tight oversize Woodruff key and *Devcon it all together!
*Devcon is a high duty epoxy/metal mix paste-adhesive/filler, which can be drilled and tapped after it is cured
R.I.P. January 2010.
XM 2.1 auto VSX 1996 - Bosch Inj, Xantia HDi 90 estate 1999, Xantia 1.9TD 1997
Previously...
GS 1970, Dyane 1974, Xantia 94 VSX TD, XM 94, 2.1 auto - Lucas Inj, XM 92 2.1 estate - Lucas Inj
Previously...
XUD bottom pulley loose contd.
I have made the new Woodruff Key from high tensile bolt material, and oil quenched it from red - then 'tempered' back to blue colour as shown. I have made the key much longer than std. so that it relays both the cam drive pulley, as well as eventually the engine dampler/aux drive pulleys together.
Now fitted the cogged cam drive bottom pulley with Locktite #638. When this has set, I will renew the cambelt and replace the engine damper pulley.
See: http://www.topcorp1.com/swing/top.html
The advice was good, as it caused me to take a closer look at the pulley, which certainly saved catastrophic engine failure.
Previously...
Previously...
