Have a look here: http://www.itsnoteasybeinggreen.org/for ... b86719460brossnunn wrote:I've not read all the replys so excuse if these has been said before.
We live out in the middle of nowhere & have been thinking the same thing, however using the standard XUD, standard cooling etc, mounted in a box with a grille at one end & a exhaust outlet at the other (much like it is under the bonnet), we'd then replace all the ancillary belt driven devices with small generators. The engine revs would be permanently set at the maximum torque range for the engine & left to run.
The electronics side would work in that any extra power that was produced would be sent back into the grid (thus getting a rebate off the bill)
The engine would be serviced just like a standard XUD & would run on drum barrels of diesel & veg oil fed through a Y in the pipe. The barrels could be changed in a similar way to the big red gas bottles do which feed our house.
However it would not be running 24/7 it would only be used as a backup device in the event of power failure or maybe run once a week to help keep the elecy bills down.
There are a few people who have got the grid hookup required and will probably be able to advise you.
Regards
