aux belt tensioner on a 2.1 xantia
- windysurferuk
- windysurferuk
i've had a strange noise on my 2.1td xantia since i got it in the summer it's a sort of droning noise on and off and only when cold, today i had a look under it to find the alternator belt flapping about on the bottom of the run, once the car is warm it's fine and the belt seems to be tight, is there any kind of adjustment that can be made or is it all automatic
- Xaccers
- x 184
Could anyone explain why my 1.9TD with a/c 97 Xantia has the same tensioners as a 2.1?
ie parts 3, 5 & 7
http://www.citroen-pr.net/catalogues/il ... 32051A.gif
Haynes manual shows it as having completely different ones.
ie parts 3, 5 & 7
DIY sphere tool
DIY sphere tool
- My Cars: Citroens since 1990, BX Diesel, GTI, TZD with 1.9 TD running extra boost before it was fashionable!, ZX Volcane TD, S2 Xantia break 1.9TD, Xantia HDI 110, currently zipping about in a C2 Diesel. C2 died from the dreaded worm, C3 Picasso HDI Exclusive, the adventure continues.
- x 31
I have just replaced the tensioner and the idle pulley on my 1.9td, quite a fiddly job but got there in the end, made the car an awfull lot quieter now the belt is not slapping. I got the bits from gsf for around £80, noticed the pulley is now made out of palstic, i would allow 4 hours or so to do the job if you havent done one before.
I've just changed the auto (top) tensioner on my 1999 1.9TD SX. It was not that noisy but I already had the hyd pump, alternator and casting that holds the tensioner removed to get to the aircon pump bolts.
I noticed two things. The tensioner had play and the bearings were noisy.... and it was sticking on the pivot. What that was doing was making it auto tension through about half the normal range. That would be a damn good reason for the common belt flap and associated noise.
Unfortunately the tensioner wheel/bearing/alloy mount/pivot bolt are all one part (no. 3 in http://www.citroen-pr.net/catalogues/il ... 32051A.gif ). Cost over £70!!
When the casting where the tensioner is mounted is off the engine it is easy to test the range and smoothness of movement with a sump drain square headed adaptor in the recess provided... and a 1/2" drive T-bar. The spring is so strong though that you might confuse this pivot seizing with it just being the tension. With the spring off it is easier to feel.
If your tensioner wheel bearing is smooth the main assembly pivot can be stripped/cleaned/greased in no time (EDIT: Or so it seemed until I just cleaned all the gunge off the old one. See my next post below) without having to buy anything.
As red5 says allow plenty of time. One of the most tricky bits on mine was that the aircon "bottle" (bit with the sight glass) nearly stopped the alternator coming out.
Anyway that is another job ticked off!
DW
DW
2009 C5 HDi VTR+Nav Tourer
2006 C3 HDi Desire
2006 C3 HDi Desire
Further to my post above I've just had a look at the old auto tensioner assy before throwing it away. I said above that if it was just a stiff pivot you could easily clean and grease. Well so it looked but never bothered to take one apart before as no need with a new pivot being part of the new assy.
Examining it properly explains why the auto tensioner fails to work properly and why Citroen supply the full assy not just the pulley.
The pivot is a steel tube with a through bolt running in two roller bearings fitted to the alloy housing.
At each end of the steel bearing tube there were deep imprints of the matching roller! I mean about 40-50% of the roller dia. This meant that the effect of the spring tension was to not only follow the belt as designed but also to hold the rollers tight in these dips. The spring operates at one end of the bearing and the bearing at the other so there is a end force at well as rotational one. It will be this end force causing the "brinelling" of the bearing.
Actually much in the same way as the Citroen rear arms... and a problem with all bearings that do not constantly rotate.
I have some great images if they could be mailed to someone who would host them and post here.
David
David
2006 C3 HDi Desire
2006 C3 HDi Desire
Richard,
Cleared out the whole mail system about 6mths ago so no old details. As in a previous post today I'm happy to leave this old disposable mail address up here until you've seen it and got in touch. Then I'll mail the images.
woollard etc......
Thanks,
David
woollard etc......
Thanks,
David
2006 C3 HDi Desire
2006 C3 HDi Desire
The bit I fitted to a 1.9TD (1999) was... 3: 575130 ALTERNATOR TENSION ROLLER £86.84
With discount it cost me £73.81 inc vat.
I think the £230 was for everything... the top tensioner above plus the bottom manual tensioner and the spring for the top tensioner.
To be honest having seen the pivot problems I mentioned I wonder if the spring might not be the problem but more the fact it is prevented from springing smoothly.
David
David
2006 C3 HDi Desire
2006 C3 HDi Desire
this tensioner business has got me baffled, first off my crank pulley looks like it's got a slight buckle in it not as much as i first thought it's maybe about 2mm out off true, ive had it off and it all looks solid a new one is £144 dealer only part, so i'm not about to rush out and pay that unless i'm sure it needs replacing.
i'm also suffering from the flapping belt on tickover, i've had the belt off and both tensioner rollers feel smooth and the spring feels free and strong enough, the belt looks quite old but the tensioner is not at the end of it's travel so i don't see this being the problem either.
