Our recently acquired '85 CX25ie is series 1 of course, but being late S1 it received the climate control aircon system that apparently was installed into Prestiges and Series 2 cars.
The problem appears to be that the AC is working fine (rear AC gets very cold and the front TX valve and pipes get very cold) but I believe the flap in the airbox somewhere is either stuck or its electronic control has fritzed.
What I want to do, to enable Mrs UFO to remain cool, is to manually move the flap so that the only air flowing into the car through the vent system goes over the AC evap and not over the heater core. I have put a tap in place to ensure the heater core is not getting hot coolant feed in the meantime.
Can someone give me an idea if/where I might find the flap so that I might be able to move it? Is best access from the left or right side inside the car OR is it something I can do from the engine bay.
I am sure someone may have an idea. Please....
