Anybody know where the rear screen relay is on a xantia 97 TD estate ?
Also the fuse location too? cheers GAry
xantia 1997 1905cc TD Estate Rear Screen Heater
- ukmobileman
- Contact:
The screen timer relay is located on the steering column panel - it's one of
two relays on the left of the fuse panel - from the illustration I have in the
Cit manual it's the one furthest away from the engine bulkhead LHS on this
panel - the fuses for the mirror heating as well, as per Mr Haynes are F19,
F23 & F27. It's a 5 pin one if that helps you pin it down (no pun intended!).
Andrew
Andrew
