Activa alloys on a Xantia HDi
As the Activa and the Td have finally both died and I recently put new Michelin tyres on the Activa I thought I would keep the alloys for the HDi when it needs new tyres.
Is there any reason this is a bad idea, The tyre size is the same.
03 Renault Master Dci 70k miles
02 406 HDi 110 65k miles
I ran with the wheels off my Activa on my C5 for a while. My C5 alloys were on my Activa while I did this.
I was trying something with the tyre pressure sensors on the C5.. to see what the computer would do if it saw no sensors at all.
The bottom line is that the Activa Alloys fitted perfectly to the C5 and so should look great on your Hdi.
Cheers, Kev
Cheers, Kev
Cheers, Kev
- Xaccers
- x 184
I'm currently running activa alloys on the rear of my 2.1TD and 1.9TD steels on the front.
Swapped them over with the 1.9 because the nearside activa alloy has a bulge on the tyre wall.
No problems.
I must get the activa alloy tyres renewed as soon as I can though!
No problems.
DIY sphere tool
DIY sphere tool
- My Cars: Citroens since 1990, BX Diesel, GTI, TZD with 1.9 TD running extra boost before it was fashionable!, ZX Volcane TD, S2 Xantia break 1.9TD, Xantia HDI 110, currently zipping about in a C2 Diesel. C2 died from the dreaded worm, C3 Picasso HDI Exclusive, the adventure continues.
- x 31
njr - there is a comprehensive list of wheel bolts and their applications here:
http://www2.qha.com/catalogues/KL1.pdf
jeremy
The bolts are m10 thread 1.25 pitch with a square edged shoulder to the
head of the bolt on the Activa alloy wheel bolts compared to the standard
saloons' 60 degree tapered head bolts with their deep head. I believe you
can't use the bolts in either alternate direction! The Activa alloys use the
same bolts as seen on alloys fitted to a Citroen CX and Pug 205.
Andrew
Andrew
Cheers everyone
That makes sense Andrew thanks, I have just been outside trying to get the buggers on and couldnt. Felt like the bolts were a little too short.
Rang Citroen and the bolts are 4.38 each plus VAT so will have to find some elsewhere. The really annoying thing was when I gave the car to a mate I didnt think to keep the bolts just the wheels.
That's Nice !
Yes, that interior looks lovely ! 8)
Re: That's Nice !
And it does not state she is not included with the sale, £100 looks like a bargain, you could just scrap the carACTIVE8 wrote:Yes, that interior looks lovely ! 8)
Now Citrtoenless
Now Citrtoenless
The wheel bolts are the same flat shouldered bolts with washers which are found on the 205 and 309 1.9 GTis.
DON'T use the standard angled shouldered bolts as these will:
1. Knacker your alloys
2. Is extremely dangerous, as the bolts have a tendancy to come loose!
You have been warned!
2004 Berlingo Multispace HDI, 105000
As mentioned, Peugeot alloy wheel bolts;
http://cgi.ebay.co.uk/16-X-PEUGEOT-ALLO ... dZViewItem
Happy ebaying!
Andrew
Happy ebaying!
Andrew
