Internal Leakage Xantia NOT CURED
jeremy
My Cars:
Post by jeremy »
Peter - has your XM got a FDV - or a 2 outlet pump like the post 94 Xantias?
jeremy
davetd
My Cars:
Post by davetd »
I have had the hydraulic system behave and then go back to misbehaviour several times, like when changing the accu sphere, or bleeding front brakes.
I believe the brake valve (doseur?????) can't fail or cause the symptoms of my problem, (according to Citroen), so maybe it is the FDV. I spoke to Citroen today who quoted over 200 quid :shock: .
Should I get alot of fluid squirting from the return pipes on the ABS, Brake or FDV valves?
thanks in advance :lol:
davetd
93 Xantia SX TD Manual Metallic Grey 145,000 Non Anti-Sink
davetd
My Cars:
Post by davetd »
Can I just confirm..........
The sound I should get from the regulator.
Some times it clicks. Some times it whooshes. By this I mean the sound the pump makes when the car is rising from lowest setting every morning (non anti sink).
Should it do both?
The whooshes vary in length and frequency, and then some times you get a click. This is all while the car is idling at normal height.
I'm just trying to give as much background as possible. :?
thankyou
davetd
Post Reply
