Auto tensioner lasts how long?
To throw my hat in the ring - I've got similar problems with my car right now.....
Last weekend I replaced the auto-tensioner - not an easy job as you have to remove the hydraulic pump and alternator to get the tensioner mounting bracket out of the car to replace the idle wheel/spring mechanism. But that's another story...
The auto-tensioner has a 10mm (or 3/8") square socket in the tensioner arm, and the only way you can get enough movement on the rachet is to remove the CPU box, and if necessary, the plastic engine mount cover as well. If you really want more room to swing the ratchet, I found that raising the engine with the top mount off was the way to go (IMHO)....
Even with this new auto-tensioner, the belt still flaps quite a lot at idle and I've still got an unusual squealing sound (I'm checking out the harmonic balancer/crankshaft pulley this weekend)....
Proud owner of two Citroens:-
'R' reg 1998 Xantia 1.9 TD Temptation Estate.
'N' reg 1996 ZX 1.9 TD Aura Estate.
'13 3008 1.6 HDi GripControl - x 984
Funnily enough mine is doing this - tensioner banging on the timing cover - it makes a hell of a racket at cold start. It is not a common failure on UK cars - I have not heard it before (and I can hear and recognise an XUD coming before I see it ). The tensioner costs around the same £80 here in the UK - I helped my mate change one, but that was because the bearing was noisy rather than the spring knackered. It is worse on mine since I fitted an aftermarket belt rather than the Lemforder OE one (I had a 1690 from GSF but that wasn't going near. A 1710 went on OK) - I have it adjusted to just stop it squealing, which helps to minimise the noise from the tensioner - perhaps in hot countries the belts just get too floppy and flap about, causing the spring the go soft?
I guess I should change the tensioner, but that's £80 and half a days work, and I'm hoping to get an HDi soon.
Needs new glowplugs as well, and the MOT is not far away
i knackered one driving through a very deep puddle....little bit of water into it and watch your bearing go.........
M reg xantia 1.9td 266000 miles expired
R reg xantia 1.9td 186000 miles veggy power expired
L reg renault clio 1.9D 91000 miles expired at 107000 miles
x reg clio 15d veggy power bottom of the car rotted through
06 c5 2.2 TD wowser so much power and comfort 160000 miles
Perhaps, or it could be the tensioner itself going soft in the heat. Maybe a longer belt should keep the tension low and preserve the tensioner strength. Mine is a 1400 with Ac, maybe too tight.perhaps in hot countries the belts just get too floppy and flap about, causing the spring the go soft?
Xantia 1.9TD 1996
If, as I suspect, you mean a 1700... then yes it is too tight which will pretty soon destroy your tensioner bearing causing the belt to shred and the possibility of the belt remnants entering the cambelt cover and causing the cambelt to break !!!!!JohnCKL wrote:Perhaps, or it could be the tensioner itself going soft in the heat. Maybe a longer belt should keep the tension low and preserve the tensioner strength. Mine is a 1400 with Ac, maybe too tight.perhaps in hot countries the belts just get too floppy and flap about, causing the spring the go soft?
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
2001 Xantia 3.0 Exclusive
1999 Xantia 1.9TD
1997 Xantia 3.0 Exclusive
1995 XM 3.0 Exclusive Estate
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
1999 Xantia 1.9TD
Thanks for the site. Very useful. Different years, different lengths of belt. 1993-6/95 is 1700, 7/95-01 Harrison is 1738 and 7/95-01 Sanden is 1725. Mine is a 96, so should be longer belt, with Sanden, its 1725 then. No wonder our tensioners are quitting early. Too much tension with a tight 1700 belt.Stewart - have a look at the Quinton Hazell catalogue - I think the belt dimensions are coded in their number - QA - R(ibbed)6(number of ribs)1360(length in mm)
http://www2.qha.com/catalogues/QH02.pdf
Xantia 1.9TD 1996
Just to let you guy's know, I had the same flappy aux belt and noisey tensioner on my Xantia hdi. I initailly changed the tensioner and things improved for a while, though I noticed that the flaping belt (bottom run) was still present. Further investigation revealled that the crankshaft pulley, which is a two part pulley, had gone out of round. That is to say, the outer had gone off centre and as the pulley rotated it increased, then decreased the aux belt tension. This intern led to the aux belt tensioner to wearing excessively and the belt to flap around (which can be noisey at idle). You shoud consider this as the cranksahft pulley is famous for failing at around 90K.
Good luck.
Good luck.
I still haven't checked mine.
I was going to change it when I did the timing belt recently. But the one GSF gave me was for an HDI - and it didn't fit!
On calling GSF and then returning the HDI crank pulley, both branches say they don't do a bonded pulley for the 1.9TD. Does anyone know if the older solid pulleys and the newer bonded pulleys are interchangeable?
Pug Rifter long (20) - 41mpg - Gutsy for a 1.5!
Xantia 1.9 TD Temp.2 Break (97) - 208K@42mpg - Resting again.
Berlingo Multispace 1.6 16v (51) - 184K@36mpg - My shed! Still runs 15° retarded...
- My Cars: Citroens since 1990, BX Diesel, GTI, TZD with 1.9 TD running extra boost before it was fashionable!, ZX Volcane TD, S2 Xantia break 1.9TD, Xantia HDI 110, currently zipping about in a C2 Diesel. C2 died from the dreaded worm, C3 Picasso HDI Exclusive, the adventure continues.
- x 31
I have a non bonded pulley from my BX TZD, it will fit in place of the bonded one but is slightly smaller in diameter than the bonded item and a lot lighter.
Stewart
Stewart
Thanks Stewart. I guessed an older one would fit; but without checking I wasn't sure about the grooves for the aux belt and the diameter. The rubber ring on my pulley still appears fairly solid but the rubber is cracking. I did take the opportunity to score some reference marks across it while it was off but I haven't checked them yet.
