Lower ball joint on the xantia
- KennyW
- My Cars: Current Citroen's
C5 x7 2010
SWMBO C3 2012
Previous Citroen's
Xantia 2.0 90hp estate
Xantia 1.9 TD estate - x 132
Malcolm and other citroen buffs,
I was refering to the hub nut NOT the lower ball joint when I was talking about the impact wrench.
But your wise advise re the specialist tool breaking with the wrench is taken onboard.
I've seen a corded impact wrench which goes to 440Nm2
I'm going to my pal's garage to see what they have otherwise it will be the scaffolding pole trick which I've used in the past on other cars.
Hope I've clear the mud
Cheers
Kenny.
Cheers
Kenny.
C5 x7 2.0 HDi 160 hp Estate exclusive, the newbie
C3 1.4 petrol (SWMBO)
- KennyW
C5 x7 2010
SWMBO C3 2012
Previous Citroen's
Thanks Malcolm,
As usual, somebody out there has the knowledge.
Silly question time what size is the hub/driveshaft nut
Cheers
Kenny
Cheers
Kenny
dont refit useing a scafold bar,just the 2 foot knuckle bar is adaquetAndersDK wrote:Fitting is the reversal ...andmcit wrote:35mm - ' ... ' - 3/4" drive
on a 2' bar extension and a scaffold or jack handle tube does the job for me.
Andrew
Meaning the torque needed is what you can do this way 8)
regards malcolm
- KennyW
C5 x7 2010
SWMBO C3 2012
Previous Citroen's
Thanks Guys
Job done, Here are few thoughts for anybodys info.
I think the best way to remove the lower ball joint is by removing the hub carrier.I also removed the drop links for ease of refitting.
Placing the hub carrier in vice and gently apply heat to area surrounding the joint followed by some gentle tapping of surrounding area , then removing the joint with silston.
I refitted with special tool.
I spoke to a mechanic who specialises in Citroens (20yrs+) and removes hub carrier and then uses specialist tool with 35mm impact socket and impact wrench , success every time.
These are the originals and the car's done 180,000 miles and rising.
So thanks to everone who contributed
Kenny
Kenny
